What is the ratio of radii for the two species X+ and X2+?
The discussion revolves around finding the ratio of the radii (r1/r2) for the singly ionized species X+ and the doubly ionized species X2+. Both species are subjected to the same electric potential and magnetic field, leading to circular motion. The charge of X2+ is twice that of X+, which affects their velocities due to differences in acceleration. After analyzing the equations for the radii, it becomes clear that the ratio is influenced by the charge and resulting velocities, leading to confusion about whether the ratio is 2 or the square root of 2. Ultimately, the correct interpretation involves recognizing that the velocity of X2+ is proportional to its charge, clarifying the ratio as square root of 2.
KatieD
The ion source is a spectrometer produces both singly and doubly ionized species, X+ and X2+. The difference in mass between these species is too small to be detected. Both species are accelerated through the same electric potential difference, and both experience the same magnetic field, which causes them to move on circular paths. The radius of the path for the species X+ is r1 while the radius for species X2+ is r2. Find the ratio r1/r2 of the radii.
So this means:
m1=m2
V1=V2
B1=B2
r=mv/qV
We know that the charge of the X2+ is twice the X. I am just so confused about where to go from here. My teacher has written out the solution but it still makes no sense.
Please help :(
Katie
You just about have it with your equation don't you?
Consider the equation for each particle.
Now take the ratio of the equations.
If the masses are virtually identical, the acceleration through the electrical potential and hence the velocities are also the same then aren't they?
By the time you get through canceling things out it looks to me like you can determine r1/r2 by inspection.
so here's where i am at:
r1=mv/qB
r2=mv/2qB
I then divide r1 and r2 getting
((m1v1)/(qB))/((m2v2)/(2qB))
then with canceling out I get r1/r2=2
I am confused, the teachers notes say its the square root of 2, I am not sure where this comes in
r1=mv/qB
r2=mv/2qB
Oops. Sorry. The acceleration through the electrical potential will result in a velocity that is not identical. It will be different how?
EPE= Vq
so if the force goes up... and the mass is the same the acceleration will have to go up with the second one by 2 right?
KatieD said:
EPE= Vq
I think they want you to accelerate that from rest. So ...
W = q*ΔV = 1/2*m*v2
Which means that the ratio of v2 = 2:1, since v2 is proportional to the charge.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
