What Is the Torque About the Knee at Different Leg Angles?
  • Thread starter Thread starter bmandrade
    Torque
The discussion focuses on calculating the torque about the knee at various leg angles while lifting a 7.5 kg object. The torque is determined using the equation torque = rF sin(angle), with the weight converted to Newtons (73.5 N). Calculations show that at 0 degrees, the torque is 0 N.m; at 30 degrees, it is 25.4 N.m; at 60 degrees, it is 12.7 N.m; and at 90 degrees, the torque is also 0 N.m due to the weight acting directly through the pivot. The importance of using cosine for determining the effective distance at different angles is emphasized, confirming that no torque is generated when the leg is vertical. Understanding the relationship between angle and torque is crucial for solving similar physics problems.
bmandrade
I need to solve a problem where a 7.5 Kg object is attached to an ankle and leg lifts are done. There is a picture that shows the leg being at rest where the angle is 0, then legs its lift to 30 degree angle, 60 and 90 degree angle
I am suppose to find the torque about the knee due to this weight for the 4 positions (each angle)
torque = rF sin (angle)
So i used the equaiton above to solve this problem which gave me
at 0 degrees = 0 N.m
at 30 degrees = 15 N.m
at 60 degrees = 25 N.m
at 90 degrees = 30 N.m
is this right?
is this right?
How many Newtons is 7.5 kg ?
Do you have access to any Sine tables to look up the values of Sine for those angles?
How long is it again from the ankle to the knee? I missed seeing that in your statement.
ok 7.5 kg = 73.5 N
also the lenth of the leg is 40 cm so .4 m
bmandrade said:
ok 7.5 kg = 73.5 N
And what is that as torque over that distance - expressed as N-m?
.4 m x 73.5 N = 29.4
OK, so is that one of your answers and if so for what angle?
it would be for angle 0 right??
If the leg is laying flat when just lifted then yes. 0 degrees relative to x-axis. 1 down.
Now what is the distance of the weight from the pivot when the leg is at 30 degrees?
Which trig function gives you that distance the force is acting straight down through to the pivot?
cos
I will have to use the .4 m as the side of the triagle the 30 degree angle makes this way i can find the distance of the 30 degree angle by using cosine
so
.4 (cos 30) = .346 m
using this i have to plug into the torque equation do i have to use sin of 30 or no because since the force is not exactly being applied at an angle right??
bmandrade said:
cos
so
The Cos already accounts for the angle.
Using .346 m is correct.
oh ok in that cas
.346 m (73.5) = 25.4 N-m for angle 30
for angle 60 .173 m (73.5) = 12.7 N-m
for angle 90 will it be 0 since cos of 90 = 0?
bmandrade said:
oh ok in that cas
Not quite. It's Cosine taken over the original .4m not the .346 at 30 degrees.
so i would have to use cos of 60 times .4
Correct.
oh ok but still for the angle of 90 its 0 or no?
Cos 90 is zero.
Multiplying by zero covers up a lot of sins.
so at 90 there is no torque
All of the weight is acting directly through the pivot when it's straight up isn't it? Hence no moment arm no torque.
