What is the water speed as it leaves the nozzle?
The discussion focuses on calculating the speed of water as it exits a garden hose nozzle pointed vertically upward. The initial attempt involved using average velocity and kinematic equations, leading to confusion regarding the signs of the calculated values. A more efficient approach was suggested, utilizing the time it takes for the water to hit the ground, the acceleration due to gravity, and the height from which it falls. After correcting a mistake in the calculations, a new time of 0.92 seconds was proposed for further evaluation. The conversation emphasizes the importance of accurate equation application and understanding the direction of motion in physics problems.
hitemup
[/B]
Suppose you adjust your garden hose nozzle for a hard stream of water. You point the nozzle vertically upward at a height of 1.5 m above the ground. When you quickly turn off the nozzle, you hear the water striking the ground next to you for another 2.0 s.
[/B]
vavg = Δx/ Δt
vfinal2 =vinitial2 + 2ax
From the vavg equation:
vg = 1.5/2t + 10t
v0 = 1.5/2t - 10t
From the other equation
http://www4a.wolframalpha.com/Calculate/MSP/MSP10431h9ic8g7736e702600003bb73a2eg362c825?MSPStoreType=image/gif&s=34&w=238.&h=35.
http://www4a.wolframalpha.com/Calculate/MSP/MSP38881h9ic4fc19b732c400004f1gdedhga6cgg3b?MSPStoreType=image/gif&s=34&w=38.&h=18.
http://www4a.wolframalpha.com/Calculate/MSP/MSP38851h9ic4fc19b732c400002b4de3h0dg0716h1?MSPStoreType=image/gif&s=34&w=49.&h=18.
v0 was (1.5/2t - 10t).
So it becomes 0.75 - 10 = -9.25.
I think my answer is correct because I've come across the value of 9.25 on some other topics too. I'm not asking for a value correction. But what I found is minus 9.25 while others claim it is plus 9.25. Is this because of the direction of the water? Also, what about the spots I wrote (1-t). Have they simply become zero?
You wrote 1.5/2t when you meant 1.5/(2t), then used it as though it wss (1.5/2)t. t cannot possibly be 1; look at the 1-t in your diagram.
There's a much quicker way. You have the time from the last drops of water leaving the pipe to hitting the ground, you have the acceleration, and you have the net change in height. One SUVAT equation will relate these to the initial velocity.
Thanks for pointing out the silly mistake. This, unfortunately, was the first way to come to my mind. I'd better think more. :D
