Wheel-Hub System and Angular Acceleration
The discussion centers on calculating the angular acceleration of a wheel-hub system with given parameters: a wheel radius of 0.8m, a hub radius of 0.4m, and a moment of inertia of 1.34 kg m². Two masses, m1=0.88 kg and m2=1.6 kg, are involved, with m2 hanging from the hub and m1 from the wheel. The correct magnitude of acceleration for mass m2 is determined to be a=3.9 m/s², based on the equilibrium conditions and the application of torque equations.
  • Understanding of rotational dynamics and torque equations
  • Familiarity with moment of inertia calculations
  • Knowledge of Newton's second law as applied to rotational systems
  • Ability to analyze forces acting on multiple bodies in a system
  • Study the principles of rotational motion and angular acceleration
  • Learn about moment of inertia for different shapes and configurations
  • Explore the relationship between linear and angular quantities in physics
  • Investigate tension forces in systems involving pulleys and multiple masses
Physics students, mechanical engineers, and anyone studying dynamics and rotational systems will benefit from this discussion.
etherealcalc
A wheel of radius r1=0.8m and hub of radius r2=0.4m is shown in the diagram. Two masses are hung from the wheel-hub system. The mass m2, on the left, is hung from the hub. The mass m1 is hung from the wheel. The system is in equilibrium. The moment of inertia for the disk-hub system is I=1.34 kg m2.
If m1=0.88 kg is large enough for the system to rotate, when m2=1.6kg, what is the magnitude of the acceleration of mass m2?
A. a=3.9 m/s2
B. a= 0.37 m/s2
C. a= 0.19 m/s2
τ= Fr=Iα
F=mg
αr=a
I thought this would work: Fr=Iα
(1.6*9.8-.88*9.8)(0.4)=1.34(a/0.4)
14.272(0.4)(0.4)/1.34=a
a=1.70
I also thought that maybe I should have just focused on the force from m2, but that wasn't it either (a=1.87)
The Arm of m1g and m2g are different. You Should try again and read the problem carefully.
In addition to Enelafoxa's point, the two masses also need a forces to accelerate them.
Create variables for the string tensions and consider the forces and accelerations of all three bodies (the two masses and the disk+hub) separately.
