Which terms should be grouped together for factorization?
The discussion focuses on the expression r^2 - xyr + (r^2)s + (x)r^2 - (y)r^2 + rsy and the challenges of factorization. Participants suggest starting by grouping terms that share the variable r. However, it is noted that the expression does not lend itself to straightforward factorization. Ultimately, while some terms can be grouped and factored out, the overall factorization remains complex and incomplete. The consensus is that a simple factorization solution is not achievable for this expression.
Johnny Leong
Which terms should be grouped together for factorization? Please give some comments.
First they all have r, start from there, the group those with similar variables.
I found that this question cannot be factorized as a very simple answer. If really do factorization, only group several terms together, factorize something out but then cannot proceed.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
