Why does superfluid helium in a spinning bucket have angular momentum?
When a bucket filled with superfluid Helium-4 is spun, it develops irrotational vortex lines that carry angular momentum, despite starting at rest. The absence of friction between the superfluid and the bucket does not prevent the fluid from acquiring angular momentum; instead, the normal component of the superfluid, which has viscosity, interacts with the bucket wall to initiate rotation. This interaction leads to the formation of vortices in the superfluid, which are quantized due to the coherent nature of the fluid. The circulation of momentum around a closed loop in the superfluid is linked to the phase variation of its wave function, resulting in quantized circulation. This phenomenon illustrates the unique behavior of superfluids compared to classical fluids.
SunSmellsLoud
Suppose you have a bucket filled with superfluid Helium-4 and you spin it with a large angular velocity Ω, the bucket obviously has angular momentum.
Spinning fast enough, the fluid develops irrotational vortex lines which carry quanta of angular momentum, while leaving the curl of the ∇xv 0, as it should be (with v the microscopic velocity field).
My question is, supposing you start with the bucket at rest, it's obvious that the fluid has no angular momentum, but considering the fact there is no friction between the bucket and the fluid, how does the superfluid get the angular momentum needed to produce vortex lines?
I may be missing something, but since when has the presence of friction been necessary for angular momentum to be present in a body, even one composed of a superfluid?
He's asking how does spinning the bucket impart angular momentum to the fluid. If you spin a bucket containing water it is the prescence of viscous /frictional forces that result in the water gaining angular momentum. Is there an analogous situation between the events in the water filled bucket and the superfluid filled bucket?
The superfluid consists of a superfluid component as well as a normal component. The normal component starts to rotate because it has nonzero viscocity and nonzero friction against the bucket wall. Then the interaction between the normal component and the superfluid component causes the vortices to appear.
I'm an undergrad in physics so don't think I'm a surprised expert. Could you show me the evidence for this phenomenon? It seems pretty interesting...
When you calculate the circulation of the momentum around a closed loop, you can show that it is equal to the variation of the phase of the wave function along the loop. Moreover, only the coherent part of the fluid can contribute to this circulation. Since the loop is closed, this implies that this variation is a multiple of 2π. As a result, the circulation of the coherent part of the fluid is quantized. This is by definition the superfluid. The superfluid can totally decouple from the normal fluid.
Find more details about this in this preprint,
http://arxiv.org/abs/1403.5472
Or if you have access to APS journals, the published version of this article is Phys. Rev. B 90, 134503 (2014).
http://journals.aps.org/prb/abstract/10.1103/PhysRevB.90.134503
Likes Greg Bernhardt
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
