Why is my calculated resistance higher than the resistor used
The calculated total resistance of the circuit is higher than the resistor's labeled value due to additional resistance from the measuring devices and connections. The user measured a 100Ω resistor at 97Ω but calculated total resistances of 114.9Ω and 113.63Ω at different voltage levels. Voltage drops across the resistor were observed, indicating potential issues with the current meter or connections. The discussion highlights the importance of ensuring accurate measurements and considering all components in the circuit, including the effects of the DMM and connections. Further investigation into the setup and measurements is necessary to resolve the discrepancies.
Daniel2244
Why is my calculated total resistance of the circuit higher than the resistor used in series and the theoretical total resistance? In a series circuit I used a 100Ω resistor and measured the current at 1.0v intervals from 1.0-5.0v.
At 1.0v the current was 8.70mA using a 100Ω resistor
2.0v - 17.60mA
The 100Ω resistor measured 97Ω using a DMM
DC circuit was used.
R=V/I, Rt=R1+R2+R3+Rn...
The theoretical total resistance of the series circuit is equal to the sum of resistor(s) (97Ω).
Calculating total resistance at different voltage outputs: 8.70mA x 0.001=0.0087A
at 1.0V total resistance = 1/0.0087=114.9Ω
17.60x0.001= 0.0176 at 2.0V total resistance = 2v/0.0176A=113.63Ω
I have no explanation on how the total resistance can exceed the 98Ω resistor.
Did you measure the actual resistance of the resistor (with an ohmmeter), or did you assume that its value was exactly its labeled value? What tolerance was it labeled to have?
Likes FactChecker
It was a 100Ω resistor and I used a digital mulimeter on ohmnmeter setting to measure the resistance of 98Ω.
Okay. How were the voltage levels established? Did you measure them each time? If so, with what instrument?
voltage were measured in 1.0v steps - 1.0v, 2.0v, 3.0v, 4.0v, 5.0v
With your DMM? How about the current?
yes with the DMM and the current for 1.0v - 8.70mA and 2.0v -17.60mA
You had a single DMM to measure all the values? So you couldn't measure the voltage and current at the same time?
I used two DMM one for current and one for voltage
Did you measure the voltage across the supply or across the resistor? In other words, was the current-measuring DMM included as part of the "load resistance"?
Have you got a make and model for the dmm?
I measured the voltage across both power pack and resistor
no. I am not sure why both of you are talking about the DMM.
There are four "variables" in your circuit: The power supply, the resistor, and two meters. One meter is inserted in series to measure the current. If it happened to be a really poor meter, it might present more resistance than you expect.
You took both readings in each case? Were the two readings the same in each case?
What did you find for the other voltage values (3,4, and 5 volts)?
gneill said:
There are four "variables" in your circuit: The power supply, the resistor, and two meters. One meter is inserted in series to measure the current. If it happened to be a really poor meter, it might present more resistance than you expect.You took both readings in each case? Were the two readings the same in each case?
No, the voltage across the resistors decrease (isn't this potential difference?) at 1v- 0.89across component (ac for short) 2v- 1.20v, 3v-2.80v, 4v-3.72v, 5v-4.65v
3v- 28.2mA, 4v- 38mA, 5v-48.3mA
Okay. So there's an additional potential drop occurring somewhere else in your circuit. The candidates include unexpected connector resistance, and the current meter. Did you ever measure the potential across the current meter for any of the setups?
Are you certain that both of your DMMs were set on DC ranges and not AC by accident?
No, I didn't measure p.d across DMM (used to measure current)
No, I positive that they were set of DC
Too bad. It would be interesting to track down where the unexpected potential drop occurred.
This is how I set up my circuit: https://gyazo.com/72f50f46557719cabcdd93b9a31cc3dd.
So, Have I calculated the total resistance right? using the voltage output from power pack and dividing it by the current Rt=V1/A1? And the reason the calculated total resistance is higher than the theoretical total resistance and the resistor used is because there is added resistance from the DMM and power pack?
Yes, the total load resistance is ##R_t = V_1/A_1##. This would include any resistance in the connectors, wires, and current meter DMM. It would not, however, include the internal resistance of the battery (power pack) as presumably ##V_1## is being measured at its external terminals. Any voltage drop due to its internal resistance takes place where you can't see it. All you can "see" is the voltage at its terminals, which presumably you are manually adjusting to read 1 V, 2 V, 3 V, ...
This can't be correct as for the 2nd resistor I used 220Ω with the measured value of 218Ω on the ohmmeter (in series). If a voltage output 1.0v the current was 03.1mA. Using the equation R=V/I changing mA to A 03.1 becomes 0.0031. Putting the numbers into equation R=1/0.0031= 322.58Ω which cannot be correct that's 104Ω higher than the actual value
If you are measuring the voltage across the power supply and the current in the circuit, then the load is everything connected to the power supply:
So something must be fishy with that DMM you're using for the current readings. Is it autoranging or do you have to select particular ranges manually for the current?
Manually, I selected milliamps because the current was very small.
I don't suppose you snapped any pictures of the lab setup? It's a good idea to do so. Sometimes one forgets to note a detail during the lab and can refer to the pictures. I think it would be helpful to know more about the make and model of the DMM.
An "ideal" voltmeter would have an infinite resistance so that it didn't act like another load resistor.
An "ideal" current meter would have zero resistance so that there was no voltage drop across it as that would also affect the circuit you were measuring.
Most modern DMM are close to "ideal" but aren't perfect. That's why we were asking about your DMM. However the size of the error makes this unlikely to be the cause of the discrepancy
Was the battery in the DMM ok?
Does it look like a normal commercial product or has someone put it in a wooden box?
Yeah, everything looked fine. The used was a standard commercial one.
Would the resistor becoming un-clipped cause such a high resistance?
Yes, or if the contact was poor. Corroded contacts can have this effect.
What sort of connections were made between components?
No I didn't, however I will in future
Crocodile clips
On my meter poor contact at the probes gives an error of a few ohms. I suppose that sort of thing might account for your 13ohm error in 100 =13%. It's harder to explain a 100 ohm error in 200= 50% error??
  • #31
+ If my component did un-clip the circuit would become broken and no current would flow
  • #32
Does your DMM require you to move one of the probe connections on the meter to a different jack for measuring current ? Some DMMs require this.
  • #33
I don't use probes I use wires connecting into the circuit
  • #34
Even so, you must make the connections to the correct inputs on the meters.
  • #35
Yes, sorry, I misread. They is 3 sockets connection socket, V,mV,micro-V, mA,micro-A and the last socket for 10 amps
  • #36
Well, I'm afraid that nothing else is coming to mind that would explain the discrepancies you've encountered. If you can get back to the lab before your report is due, set up the circuit and take voltage readings across the current-measuring DMM. Also take a close-up picture of the DMM if you can.
  • #37
I am going to redo my experiment hopefully it won't affect my grade
Likes gneill
  • #38
I know it's not relevant to my earlier question, however how would I calculate resistance of my circuit at each voltage interval in parallel set up like this : https://gyazo.com/25a70bf570d626ac0c1373184075e77d? using voltage and current? R1=V2/A3, R2=V3/A4, R3=V4/A5 than 1/Rt=1/R1 + 1/R2 = 1/R3?
  • #39
Yes that works.
However if the meters are "ideal" meters then the equivalent resistance of the lot could be calculated as Vm1/A1.
  • #40
CWatters said:
Yes that works.
I didn't think about that. thanks saves a lot of button smashing :D
  • #41
CWatters said:
Yes that works
Was meant to write R1=V1/A3, R2=V1/A4, R3=V1/A5
Because I am measuring the resistance at 1v-5v at 1v intervals
  • #42
If the meters are ideal then all the voltmeters will read the same (VM1 = VM2 = VM3 = VM4 = V1) so both methods will give the same answer.
The resistor values in the circuit are quite low (99 to 327 Ohms) compared to the resistance of most voltmeters (20K to 10M Ohm). So for example 20,000 Ohms in parallel with 327 Ohms = 322.7 Ohms so the volt meters hardly have any effect on the resistance and you can consider them to be ideal.
The internal resistance of an ammeter or DMM on the current range setting can vary. I think most are around 0.02 Ohms (eg they have a 200mV drop at 10A) but some might be more like 1 Ohm ? So for example you have a 1 Ohm meter in series with the 99 Ohm resistor = 100 Ohms. So even a 1 Ohm ammeter should only affect your circuit by 1%. so you can pretty much consider the Ammeters to be ideal as well.
  • #43
I am still getting really high resistance on each branch higher than the resistor itself and I just don't know why. The circuit was set up correctly and all the
components were fine (to my knowledge). For example, at 1V the resistance of branch 1 (R1) was 103.09Ω, branch 2 = 232.56Ω tand branch 3 = 378.78. after using the Rt equation the resistance of the circuit at 1v was 60.24Ω but I still shouldn't be having the excessive resistance of the branches. Also from 1v-5v the resistance of the circuit stay roughly the same is this corrct?
  • #44
Did you measure the voltage across any of the current-reading DMM's? Maybe snap a picture of the DMM?
  • #45
No but in future I am
  • #46
Did you implement the full circuit that you showed in post #38? You had sufficient meters to do so? If so I'm impressed by your lab's resources.
  • #47
Does the variable power supply have a meter on it and are you using that meter to set the supply voltage?
Daniel2244 said:
I am still getting really high resistance on each branch higher than the resistor itself and I just don't know why. The circuit was set up correctly and all the components were fine (to my knowledge). For example, at 1V the resistance of branch 1 (R1) was 103.09Ω, branch 2 = 232.56Ω tand branch 3 = 378.78.
When you set V1 to 1V what values did you measure for VM2, VM3 and VM4 ?
What were the corresponding currents A3, A7, A8 ?
If the meters are ideal the overall resistance calculated should stay constant but not 60 Ohms. I calculate it should be about 56 Ohms.
  • #48
I took out the DMM (amp setting) and (volt setting) and placed it where I needed to measure. For example when measuring the voltage at v1 and current at A1 I moved it to V2 and A2. I wish they had more resources would be a lot easier
  • #49
Yes, the supply pack has a meter on it, additionally I measured the output from the power pack using a voltmeter as well.
VM2 = 0.94v, VM3=0.73, VM4=0.97
A3=09.4mA, A7=4.10mA, A8=2.59
R1=1/0.0094=106.38 R2=1/0.0041=243.90 R3=1/0.00259=386.1
1/Rt=1/106.38+1/243.90+1/386.1=0.0160
Rt=1/0.0160=62.5Ω
  • #50
I'm still not clear on what the precise circuit was for each reading taken. How many meters were in play at any given time? Can you provide a figure showing the setup for taking readings?
