Why isn't this working? a simple inverse of a 2x2 matrix
  • Thread starter Thread starter mr_coffee
    Inverse Matrix
The discussion revolves around the calculation of the inverse of a 2x2 matrix A, specifically A = [-5, 3; 2, -9]. The user initially calculated the determinant incorrectly as 1/39, while the correct determinant is 39, derived from the formula ad-bc. To find the inverse, one must divide the adjoint matrix by the determinant, not the other way around. Clarifications were made regarding the calculation process, emphasizing that the inverse formula is 1/det(A) * adj(A). Correcting these misunderstandings will lead to the accurate computation of the matrix inverse.
mr_coffee
Okay i have a simple problem, and its not working!
I have the following:
Find a 2x2 matrix
A =
-5 3
2 -9
A-1 =
-3/13 -1/13
2/39 -5/39
A*A-1 = I
1 0
0 1
but its saying the inverse i got is wrong! how is this?
det i got was 1/39
Find a 2x2 matrix
A =
-5 3
2 -9
A-1 =
-3/13 -1/13
2/39 -5/39
A*A-1 = I
1 0
0 1
det i got was 1/39
Your determinant is actually 39 (not 1/39). Divide the adjoint matrix by that and you should get your answer (provided you calculated the adjoint correctly).
thanks for the responce! But how did u get a det of -39? if a determinant is defined as
1/(ad-bc)?
so if i had
-5 3
2 -9
(-5)(-9) -(3)(2) = 45 - 6 = 39, and its under 1, so 1/39?
I also tried ur answer, when u say divide the adjoint matrix, do u mean divide the matrix after switching a and d, and negating b and c? I tried that and it was also wrong with ur det
1/(ad-bc)?
so if i had
-5 3
2 -9
The determinant of a 2x2 matrix is ad-bc. I meant to say 39, not -39.
1/(ad-bc)?
No!
The inverse is 1/det(A) * adj(A) where 1/det(A) = 1/(ad-bc) so det(A) = ad-bc and not 1/(ad-bc).
