Why thunderbolts don't travel in straight lines
Thunderbolts, or lightning, do not travel in straight lines due to the nature of electron movement through the air, which acts as a medium. Electrons jump from atom to atom in a non-linear path, influenced by the easiest route available at an atomic level. The speed observed in lightning is the speed of the electrical impulse, not the slower movement of the electrons themselves. The phenomenon is further complicated by multiple pockets of electrical charge in the atmosphere, leading to a chain reaction of discharges. Understanding lightning involves recognizing these complex interactions rather than viewing it as a simple straight-line path.
Omid
Why thunderbolts don't travel in straight lines ?
I think the electrical charge likes to move in the shortest path to the Earth and the shortest path must be a straight line !
Well it's really not a "thunder" bolt since thunder is the sound produced from the expanding air. but anyway..
The lighting does take the shortest route except that you're forgetting one thing. The lighting is the passing of electrons from atom to atom. The electrons use the air as their medium of travel in this case, instead of a wire or something you that normally think of with electricity. Basically, whichever way is easiest they will take.. but you must think of it on an atomic level. It's going to be a little jumpy in the paths it takes as the impulse decends downwards.
Also a little fact, the speed it takes to get from top to bottom is not the speed the electrons move. That's the speed of the impulse. The electrons move much more slowly.
It gets much more complex than that too but I think that should be a decent explanation. :smile:
Last night the thunderbolt waked me up, right then this question appeared in my mind.
For such an immediate question this answer is very good and complete.
Thank you
This is still a heavily researched topic in physics. Sporff has it pretty much right from what I know of the subject.
A bolt of lightning, as you probably know, occurs when the difference electrical charge becomes great enough for a spark to jump from one club to another, or from a cloud to the ground. But that is the simplified version. In actuality, there are many pockets of charge differential throughout the air during a thunderstorm. With little pockets of higher and higher potential building up all over the place, when the imbalance between the two charges finally gets high enough, the electrons actually jump from one pocket to another, rather like "connect-the-dots ". If you can see it in slow motion, this actually has a chain reaction effect. Potential drained from one location increases the difference in potentials between that location and its neighbor, causing the neighbor to discharge, and so on.
What sporff told was exactly the answer I was looking for. But now with the last post some more questions are made in my mind which I just ignore them until the time that I know more of the subject :redface:
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
