Solve Magnetic Flux from Straight Wire & Rectangular Loop: Wb
A long straight wire carrying a current of 36 A creates a magnetic field affecting a rectangular loop positioned 3 cm away. The magnetic field was initially calculated using the formula B = μ * I / (2πr), yielding a value of 0.00024 T. The area of the rectangular loop was determined to be 0.01125 m², leading to a calculated magnetic flux of 2.70e-6 Wb. However, this approach is incorrect because the magnetic field is not uniform across the loop's area. To accurately find the magnetic flux, it is necessary to integrate the magnetic field over the area of the loop from 3 cm to 10.5 cm.
kiwikahuna
A long straight wire carries a current 36 A. A rectangular loop with two sides parallel to the straight wire has sides 7.5 cm and 15 cm with its near side a distance 3 cm from the straight wire as shown in the figure. The permeability of free space is 4π e -7 T*m/A. Find the magnetic flux through the rectangular loop. Answer in units of Wb.
http://img112.imageshack.us/img112/9541/mblf4.jpg
Shot at 2007-07-31
Magnetic flux = BA
B = u * I / (2*pi*r)
I found the magnetic field
B = u * I / (2*pi*r) = (4*pi*10^-7 * 36 A) / (2*pi * 0.03 m) = 0.00024 T
Then I found the area of the rectangle which A = 0.075 * 0.15 = 0.01125
I multipled BA to get the magnetic flux. My final answer was 2.70e-6 Wb but this answer is wrong. Could someone please tell me what I'm doing wrong? Thank you.
the magnetic field is not constant throughout the area. therefore you have to integrate B*dA, the flux, from r=3 cm to r=3+7.5= 10.5 cm
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
