Solving the Mystery of 7 Three-Way Switches & 7 Lights
The discussion revolves around creating a complex wiring system involving seven three-way switches and seven lights, where each switch controls specific lights in a sequential manner and allows for reverse operation. The user seeks a wiring diagram to achieve this setup, acknowledging that it would not comply with electrical codes. The proposed solution involves using single-throw double-pole switches and configuring them to control multiple lights in a cascading manner. The concept is likened to historical wiring methods used in mines. Overall, the user is looking for technical assistance to implement this intricate lighting control system.
jdogohoover
have been told there is a way to make this mystery below work and can't figure it out. I know it wouldn't be up to code and i would never do it but if someone could hook me up with a wire diagram of how its done i really appreciate it. I am pretty sure switching the neutral is involved electrician,
there are 7 three way switches and 7 lights and the switches need to work like described below and it also has to work in reverse from switch 7 back to switch 1. please please help
ok, all the switches are 3 way, when u turn on switch 1, light 1 and 2 comes on when u hit switch 2, light 1 goes off and 2 and 3 come on, when u hit switch 3 light 2 goes off and 3 and 4 come on, when u hit switch 4 light 3 goes off and 4 and 5 come on, switch 5, light 4 off 5 and 6 come on, switch 6 5 goes off and 6 and 7 come on when u hit switch 7 they all go off, it has to work in both directions. . susposedly it has something to do with the way lights were wired in mines.
You will need single-throw double pole, three way switches. The second switch is wired as the second switch in the three-way control for light #1 and (using the second set of contacts) the first switch in the three-way control for light #2. Just repeat that for n lights.
AM
