Women's Volleyball: Net Height & Court Limits
The problem involves women's volleyball, specifically calculating the minimum initial speed required for a jump serve to clear the net and the maximum initial speed to remain within the court boundaries. The context includes specific measurements for net height and distances from the net and endline.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss relevant equations and approaches to the problem, with one participant expressing difficulty in determining an initial velocity without time or velocity data. Another suggests synthesizing equations to describe the projectile's trajectory.
The discussion is active, with participants sharing thoughts on equations and methods. Guidance has been offered on constructing a trajectory equation, indicating a productive direction in the exploration of the problem.
Participants are navigating constraints related to the lack of initial velocity and time, which complicates their approach to solving the problem. There is an emphasis on showing work and identifying where they encounter difficulties.
linds1369
1. For women's volleyball the top of the net is 2.24m above the floor and the endline is 9.00m from the net. Using a jump serve, a player strikes the ball at a point 3.00 m above the floor and 8.00m (horizontally) from the net. If the initial velocity of the ball is horizontal and directed perpendicular to the endline, (a) calculate the minimum initial speed the ball must have to clear the net. (b) calculate the maximum initial speed the ball can have to stay inside the court.
What equations do you think are relevant? How do you think you should approach the problem?
Please show us your work and where you get stuck. We're here to help you with your homework, not to do them for you.
Well, initially I thought to find theta and solve for V0x=V0cos(theta) but I have no initial velocity. I'm stuck trying to find an equation that I don't need time or velocity for. I just can't quite figure out where to start.
Try and synthesize an equation describing the trajectory of the projectile.
[tex]x(t)=\tfrac{1}{2}a_x t^2+v_{0_x}t+x_0[/tex]
[tex]y(t)=\tfrac{1}{2}a_y t^2+v_{0_y}t+y_0[/tex]
Try and build the function [tex]y(x)[/tex] by isolating [tex]t(x)[/tex] and then plugging it into the [tex]y(t)[/tex] equation.
It should be smooth sailing from there on, just a question of plugging in the x and y values for each situation.
  • · Replies 19 ·
14K
  • · Replies 39 ·
10K
  • · Replies 38 ·
11K
