How much work is done on a crate pushed along an incline with constant velocity?
To calculate the work done on a 40 kg crate pushed up a 4 m high incline with a distance of 7 m, the formula W = m|g|h is applied, resulting in 1.3 x 10^2 J. The discussion clarifies that constant velocity does not imply zero work; instead, it indicates that the applied force must counteract gravitational forces. The kinetic energy formula W = 1/2mv^2 is not applicable here since the velocity is not provided. Trigonometry can be used to find the angle of the incline if needed, but the primary focus remains on gravitational potential energy changes. The correct approach is to calculate the work based on the change in potential energy, confirming that work is done against gravity.
thephysicslife
40 kg crate is pushed at a constant velocity along an incline with a vertical height of 4 m and inclined distance of 7 m. How much work was done on the crate in moving it to the top of the ramp?
For the incline, think of a right angle triangle with the 7 m being the hypotenuse.
W=m|g|h
W=|fa||d|
W=m*a*d
W=1/2mv2
Any dynamic equations ( I don't think they are necessary for this question though)
W=Ep
=m*|g|*H
=40kg*9.81m/s2*4m
=1.3x102 J
The thing I am unsure about is if the velocity is constant, does that mean the formula would be W=1/2mv2 and the answer would be 0 Joules because the velocity is constant? Would be find the angle of the incline using sine?
thephysicslife said:
W=Ep
=m*|g|*H
=40kg*9.81m/s2*4m
=1.3x102 J
Check your arithmetic.
That would give you the kinetic energy of the crate, if you happened to know the velocity. But you were not given the velocity. Just because a value is constant doesn't mean you can make it zero.
You have two choices here. You can calculate the change in gravitational PE as you (nearly) did above, or you can determine the force required to push the crate at a constant velocity (what force must the push counteract?). Then use the usual work formula involving force and distance.
You can use trigonometry to find the angle if you think you need it. The sine and cosine of it can be determined directly by suitable ratios of the triangle sides.[/quote]
