Help with Work & Power Problem: 60kg Student on Incline
A 60kg student running up a 4-meter incline with a height of 2.5 meters needs to calculate his power output while maintaining constant velocity. Initially, the student incorrectly assumed no work was done due to zero acceleration, leading to a power output of 0 W. However, the correct approach involves recognizing that the student must perform work against gravitational force to gain potential energy while ascending. The power output is determined by the change in energy over time, resulting in a calculated power of approximately 326.67 W. Understanding the relationship between work, energy, and power is crucial for solving such physics problems.
jCarlson
Hey everyone. I'm new to this site and was wondering if u can help me with a work and power problem. :smile:
Question:
A 60kg student runs at a constant velocity up the incline described in the diagram in 4.5s. Calculate the power output of the student.
The diagram was a picture of a right-angled triangle with hypotenuse length 4 meters. The hypotenuse is the ramp, and the ramp is raised to a height of 2.5m (also the length of the vertical leg). The student is running up the ramp.
My Work:
Since he is running at constant velocity, acceleration = 0m/s/s.
F=ma, so F = 0 N.
W=Fd, so W = 0 J.
P=W/t, so P = 0 W.
The answer from the back of the book was P = 326.67 W.
I know the student is doing work in terms of his muscles having a tensional force, but I don't think that is the way to go with this problem at all.
Anyways, any help will be appreciated thanks.
BTW, there was no information regarding friction.
The student has to overcome some gravitational pull, thus he has to generate force. Can you determine its magnitude?
The fact that the student is doing work is pivotal to finding the power. It's easier to think of this in terms of energy. The work that the student does brings him from the bottom of the incline to the top of the incline. What type of energy (kinetic or potential) changed for the student from the bottom of the cliff to the top of the cliff? Hint: The student is assumed to keep a constant velocity throughout.
What you did was assume that since the student is not accelerating, he is doing no work. But does it really make sense to think that someone can get from the bottom of a cliff to the top of the cliff without doing any work? (I made the same mistake plenty of times, so don't feel bad.)
The student's work creates a change in the student's energy, bringing him from the bottom of the incline to the top of the incline. If the work is W, then, as you already found, power is work over time.
Another way to approach this kind of problem is to write the total energy as the sum of the potential and kinetic energies:
TE = PE + KE
If his velocity is constant, are there any changes in his KE as he runs up the hill? What can you say about his PE? And then just remember that power is the amount of energy change per unit time (per second in mks units).
EDIT -- Saketh was too fast for me -- beat me to it.
Thanks for the help, I solved the problem by thinking Power as change in energy over time.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
