Solve the Homework Problem with Work and Energy
The discussion focuses on solving a physics problem involving work and energy related to a crate being pushed up a slope. The user attempts to apply the conservation of energy principle, equating work done by a force to the change in kinetic energy and potential energy. However, there is confusion regarding the correct formulation of gravitational work, with an incorrect expression involving sin(20 degrees) being highlighted. The correct potential energy should be calculated using the height directly, not adjusted by the sine of the angle. Clarification is sought on the validity of both approaches, with emphasis on the proper application of work-energy principles.
Anthonyphy2013
Doug pushes a 5.30 kg crate up a 2.20-m-high 20 degrees frictionless slope by pushing it with a constant horizontal force of 27.0 N. What is the speed of the crate as it reaches the top of the slope?
a) Solve this problem using work and energy.
Wd=delta KE, ke=.5mv^2 and pe=mgh
Conservation of energy
W.d=Pe+KE
Fcos20=mg(h/sin20)+.5mv^2
v= 3.9m/s
but I consider another way about the work done
work done = delta KE
work done on force = Fcos20
work done against the gravitational force = mg(h/sin20)
so Work done by force - work done against the gravitational force =Change of KE .
which one is a corrected concept or both make sense. thanks so much.
Anthonyphy2013 said:
...Fcos20=mg(h/sin20)+.5mv^2...
This is not correct.
why is that not corrected ?
Since work done must be equal to delta KE , so we consider workd done on gravitational force is not a conserved work done ?
Left side of the equation is force, right is energy. Potential energy is ##mgh##, not ##mg\frac{h}{\sin 20^o}##
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
