Work done by friction on potted plant
In summary, the work required to move a 2.75-kg potted plant at a constant speed along a shelf for 1.07 m is determined by finding the frictional force and multiplying it by the distance. The work done by the frictional force is positive due to sign conventions, but the work done on the plant due to friction is negative. Therefore, the work required is W = +15.8312 J.
Lolagoeslala
217
A 2.75-kg potted plant rests on the floor. Determine the work required to move the
plant at a constant speed along the shelf for 1.07 m where the coefficient of kinetic friction is 0.549
I found the Fn:
Fn = mg
Fn = 26.95 N
Ff = Fnμ
Ff = (26.95N)(0.549)
Ff = 14.79555 N
W = Ff x d
W = 14.79555 N x 1.07 m
W = - 15.8312 J
This would be negative correct?
Well the work done by the frictional force would be positive due to sign conventions. So your answer would be W = + 15.8312 J, however the work done on the plant due to friction is W = -15.8312 J.
Your answer is correct, but the sign depends on the convention used.
I don't think you need a sign convention for this.
The angle between the applied force and the displacement is 0, so the work done by the applied force must be positive.
The angle between the frictional force and the displacement is 180, so the work done by the frictional force must be negative.
would u like to expand?
You are asked for the work required to move the plant, i.e. the work done by the force that moves it. That force and the distance moved are in the same direction, so the product must be positive, no matter which way you assign the positive direction in the co-ordinate system. That is, either F and d are both negative or they're both positive, but Fd will always be positive.
1. What is "work done by friction" on a potted plant?
The term "work done by friction" refers to the energy expended when a surface rubs against another surface. In the context of a potted plant, this refers to the force required to move the plant across a surface or to lift it up.
2. Why is work done by friction important for potted plants?
Friction plays a crucial role in the movement and stability of potted plants. Without friction, the plant would easily slide or fall off the surface it is placed on, making it difficult to maintain its position.
3. How does work done by friction affect the growth of a potted plant?
The amount of work done by friction can impact the growth of a potted plant in several ways. Excessive friction can cause damage to the plant's roots or stem, limiting its ability to absorb nutrients and water. On the other hand, some amount of friction can also provide necessary resistance for the plant to strengthen its roots and grow taller.
4. Can work done by friction be reduced for potted plants?
Yes, there are ways to reduce the work done by friction on potted plants. For example, using a smooth and level surface, adding a layer of mulch or pebbles to decrease surface contact, or using a plant stand with wheels can all help reduce friction and make it easier to move or adjust the plant.
5. Is friction the only factor that affects potted plants?
No, there are several other factors that can affect the growth and health of a potted plant, such as sunlight, water, temperature, and soil nutrients. However, friction is an important factor to consider, especially when it comes to the stability and movement of the plant.
