How Does a Pump Calculate Work When Transitioning from Water to Air Underwater?
The discussion focuses on calculating the work done by a pump transitioning a closed volume from water to air underwater. The scenario involves a 1m³ container at 100m depth, where the pump expels water, creating a vacuum that allows air to enter through a one-way valve. The work is calculated using pressure and volume, with the pressure at depth being approximately 10 bar. The participants explore different methods to derive the work, emphasizing the need to account for ambient pressure changes as water is pumped out. Ultimately, understanding the mechanics of pressure changes is crucial for accurately determining the work done by the pump.
kihel
  • We have a container/volume of 1m3 100 m below mean sea level,
  • A pump connected to it, pumping from inside the volume with outlet in the surrounding water at same height.
  • And there is an pipeline to air, with a one-way valve allowing air to be sucked down to the volume and preventing anything from moving up.
    State 1 the volume is filled with water
    State 2 the volume is filled with air
What are the forces involved and how to calculate work done by a pump going from State 1 to state 2 - pumping water out of the closed volume and into the surrounding water at same height, hence creating a vacuum which sucks air down through the pipe.
Assumptions:
Ignore efficiency of the pump
Water as incompressible fluid
Energy = Pressure*Volume
Pressure = Density * Gravity * Height
Force = Pressure * Area
Pressure = Force/Area
My initial thought is that the work done that need to be done by the pump must equal the potential energy of State 2.
This energy is: E=PV, P=DGH
Pressure = ~1000 * 9,81 * 100m = ca. 10 bar = 10 000 N/m2
Energy= 1 m3 * 10 000 N/m2 = 10 000 Nm
Delta E = Heat transfer + Work done
Assuming no heat transfer and energy in state 1 is zero:
W= 1000 N/m
This however seems to me like a derived answer, I am looking for a different method, more direct calculation of actually moving the water.
Best regards Kihel
I think 1 bar = 100 000 Pa = 100 000 N/m2.
Well, it amounts to the same thing as what you've done, but you could think of it this way:
Your container is basically a cylinder with height 1 m and cross-sectional area 1 m2.
Your pump needs to push the water out against the ambient pressure, which would be just like pushing a piston into the cylinder to push out the water.
The force is therefore F = P * area of piston, and the total work would be F*(height) = P(area)(height).
To understand what is happening mechanistically, note that, as soon as you pump the slightest amount of water out of the volume, the pressure within the volume will drop to 1 atm. This is because the volume is connected by a column of air (with negligible static head) directly to the air at the surface. So the water inside the volume is being pumped from a pressure of 1 atm (1 bar) to a pressure of 11 bars (static head + surface pressure) at depth.
Chet
