How Is Work Calculated in a Forced Oscillation with Resistance During Resonance?
  • Thread starter Thread starter bour1992
    Oscillation Work
To calculate the work produced by the resistance force in a forced oscillation during resonance, the resistance force is defined as F_res = -bv, where b is the damping constant. The external force is given by F_ext = F_max * cos(ωt), and the displacement can be expressed as x = A * sin(ωt). Since the work is not constant, it can be determined by integrating the force with respect to displacement or by integrating power over time, where power is the product of force and velocity. Specifically, the work done in one period is calculated using the integral W = ∫_0^T F(t)v(t)dt, substituting F with -bv and v(t) with v_max * cos(ωt). This approach allows for the accurate calculation of work in the context of forced oscillations with resistance.
bour1992
How can I calculate the work which is produced by the resistance force in a forced oscillation in one period?
The only forces on the oscillatory body are the resistance force and the external force.
The oscillatory body is in resonance.
resistance force: F_{res}=-bv (b is the damping constant)
external force:F_{ext}= F_{max} \cbullet \cos\omega t
x=Asin\omega t
u=u_{max}cos\omega tThanks in advance
How can you calculate work in general?
ehild
the work in a constant force is: W=F*d.
Moreover the work can be calculated from the area from graph F-d.
I can't find the work with either ways.
A definition of work can be found in this http://en.wikipedia.org/wiki/Work_(physics)" .
The work is not constant here, and the area can be calculated as integral of force with respect to the displacement.
There is an other way to get work, by integrating power with respect to time for a given time period. And power (P) is the scalar product of force (F) and velocity (v). In case of one-dimensional motion,
P=Fv, and work done in one period is
<br /> W=\int_0^T{F(t)v(t)dt}<br />
You know that F =-bv, and v(t)=v_{max}cos(\omega t). Write the product of them and integrate.
ehild
