Working out EMF and internal resistance
The discussion revolves around calculating the electromotive force (EMF) and internal resistance of a power supply connected to a 10,000 Ohm resistor, with a current draw of 0.91A and a voltmeter reading of 8.3V. The initial calculations suggest a terminal voltage of 9,100V, leading to a negative internal resistance when combining equations. Participants note the possibility of a typo in the problem, proposing that the current should be 0.91mA instead. Adjusting the current to 0.91mA resolves the issue, aligning with the book's answer. The conversation highlights the importance of accurate values in electrical calculations.
PhysStudent81
Power supply of EMF = E and internal resistance of R. Need E and R.
This is connected to resistor of 10'000 Ohm. The current drawn from the power supply is 0.91A.
A voltmeter of internal resistance 10'000 Ohm is connected in parallel to the resistor. The voltmeter reads 8.3 Volts.
Original question (number 2) can be found here:
https://www.dropbox.com/s/n842i3ojnanhtxc/2013-01-13 14.37.43.jpg
V = IR and Terminal PD = E - IR, presumably.
Overall plan: Use the two situations to set up two simultaneous equations, then solve for E and R.
I'm assuming the questions is saying that the drawing of the current was independent of connecting the voltmeter.
From 1st part:
V = IR,
R = 10'000 Ohm
I = 0.91A
So V = 9'100 V
V = terminal PD so:
9'100 = E - 0.91×R (Call this 1)
From 2nd part:
Total resistance of Voltmeter and resistor is:
1/10000 + 1/10000 = 1/5000 so R_tot = 5000 Ohm.
Voltage measured is terminal voltage (8.3V)
Current is I = V/R = 8.3/5000 = (C 0.00166 A
So:
8.3 = E - 0.00166×R (Call this 2).
HOWEVER: combining 1 and 2 gives a negative internal resistance!
Any ideas what I've done wrong?
Thanks guys!
From 1st part:
V = IR,
R = 10'000 Ohm
I = 0.91A
So V = 9'100 V
V = terminal PD so:
From 2nd part:
So:
Thanks guys!
I note that they refer to it as "A power supply" and not a battery. Depending upon the complexity of the power supply and its ultimate purpose, it is possible that it will exhibit a negative internal resistance. This sort of thing is achievable with active components (amplifiers).
The potential difference across a 10 kΩ resistor carrying 0.91A would be 9100 V. I wonder if there's a typo in the book. Maybe the current was meant to be stated as .91 mA. Hard to say.
Ok thanks both of you.
I wanted to check whether I was missing something but I wasn't. It was a typo - setting the first current to 0.91mA gives the answer in the back of the book.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
