Wow, human powered ferris wheel
  • Thread starter Thread starter christyu
    Human Wheel
A human-powered Ferris wheel could be enhanced by integrating bicycles to generate power, allowing participants to pedal and contribute to its movement. Utilizing a flywheel could help store energy, providing a smoother ride by releasing energy as needed. Additionally, electromagnetic linkages could replace traditional gears and sprockets for a more innovative design. The concept sparks interest in exploring various mechanical configurations to maximize fun and efficiency. Overall, the discussion highlights creative possibilities for developing a more complex human-powered Ferris wheel.
christyu
This is quite interesting, I'm wondering if there's another way of creating human powered ferris wheel with mechanical parts.
Can anyone give any suggestion? I'd love to get more information regarding this!
Likes Greg Bernhardt
The guys that jump and hang on to a seat look to be having a lot of fun!
1) The Ferris wheel is already mechanical. Assuming you mean something more complex, you could connect bicycles. A flywheel would store energy that could be fed in as needed. The linkage could be electromagnetic instead of gear and sprocket. The mind boggles.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
