Writing equations for rate of change problems
Poppynz
Hi
Im trying to write an equation for the question below. i did write one but am pretty sure it is wrong because I need to differentiate arctan in it and we have not been taught that yet. Could someone please point me in the right direction with writing it?
A telescope is 75m above water level on a cliff and a boat is approaching at 6m/s. what is the rate of change of angle of the telescope when the boat is 75m from shore.
I thought it might be y=arctan(75/x) because the angle specified is found using arctan(opposite/addjacent).
Any suggestions appreciated :)
Poppynz said:
… I thought it might be y=arctan(75/x) because the angle specified is found using arctan(opposite/addjacent).
Hi Poppynz! :smile:
Just write it tanθ = 75/x, and differentiate both sides wrt x
from the chain rule, you'll get a sec2θ, which you can rewrite in terms of the original 75/x :wink:
Thanks that seems much easier :)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
