Young's Double Slit Experiment refraction
In the discussion on Young's double slit experiment, participants analyze the effects of placing a glass slab in front of one of the slits. The main confusion arises from whether the refraction of light through the slab affects the path difference and if lateral displacement can be neglected. Some argue that while the light bends upon entering and exiting the glass, these effects cancel out, maintaining the original path. However, others assert that lateral displacement is significant due to differing refractive indices, affecting the overall path. The conversation emphasizes the need for a clear understanding of how light behaves when transitioning between media.
Prashasti
'd' - Separation between the two slits
'D' - Separation between the double slit and the screen
'S' - Source (Primary) (It is coherent)
S1, S2 - Secondary sources
Δx - Path difference between the two rays coming out from S1 and S2
Δx° - Path difference between the two rays coming out from S1 and S2 when a glass slab with refractive index μ and thickness 't' is placed in front of one of the slits.
λ - wavelength of the light waves
d<<D
2. Homework Equations
What my teacher did was,
He said that the path difference when the glass slab is kept in front of the slit would be,
Δx° = μt-t
And then he wrote,
Δx° = d sinθ - (μt-t)
And then he did the usual calculations and, finally, got
y = [nλ + (μ-1)t]D/d
I understood all the calculations he did. But I'm confused because he didn't consider the 'refraction' of light rays that pass through the slab anywhere while deriving the expression.
Won't the rays bend?
Can the lateral displacement be neglected?
Assuming D>>t it would probably be a fairly accurate description of the situation for small ##\theta##. If it was me, I would place the glass on the entry-side of the slit, thus avoiding such inconsistencies.
Likes Prashasti
The light will bend towards the nornal when it enters the glass and will then bend away from the normal when it leaves the glass. The two effects will cancel and the original path will not change.
Likes Prashasti
Thanks.
I got it!
No. Lateral displacement is "must", because the two media are with different refractive indices.
They won't "cancel" each other's effect...rather, the emerging ray will follow a different path. (I'm pretty sure about this)
Yes, I absolutely see where you are coming from. The lateral displacement will tend to reduce the distance between the paths, BUT, the same angle ( the one between the normal to the glass surface and the beam) that causes the lateral displacement will also increase the time spent in the glass. Try drawing the glass surfaces at a slight angle to the beam and then rotate it a little bit. Do these effects cancel?
Likes Prashasti
Sorry, I didn't quite understand the point. Can you explain it diagrammatically?
If light enters the glass at 90 degrees to the planes of the glass it will go straight through with no lateral displacement. If the light goes through the glass at another angle it will have lateral displacement, but will spend longer in the glass as it has a greater distance to travel through the glass.
Likes Prashasti and henxan
