You're welcome! Glad I could help.
  • Thread starter Thread starter Stroodle
    Force Fundamental
The discussion revolves around the concept of forces in physics, specifically addressing the minimum number of objects required for a force to be present. Participants explore the implications of Newton's laws and the interpretation of physical systems.
  • Participants discuss whether one or two objects are necessary for a force to exist, with references to Newton's 3rd Law and examples involving free body diagrams.
There is a mix of perspectives, with some participants affirming the need for two objects based on Newton's 3rd Law, while others suggest that a single object can be considered in certain contexts. The conversation is ongoing, with various interpretations being explored.
Some participants reference the context of introductory physics courses, which may influence their understanding and assumptions about physical systems and forces.
Stroodle
What's the minimum number of objects required for a force to be present?
I assume it's 2, because you'd need one object to be moved and the other to apply the force. Is this correct?
Thanks
Umm... I take it you're enrolled your first physics class right now.
Anyways, when you talk about a physical system, take for example a person pushing a block, you don't count the person in the system itself. All that's there is just the block that's either moving at constant speed or undergoing uniform acceleration in the positive or negative direction. So I guess the answer to your question is 1...
Do you know what a free body diagram is? If so, in that person pushing a block example, you just draw the block and a force vector coming out of it's center, pointed in the direction at which the force is applied.
You are correct. The number is 2. Newton's 3rd Law says that forces come in pairs, so if you have a single force acting on an object (as in a free body diagram), you can safely deduce that there is another object (somewhere in the Universe and outside your free body diagram) that experiences a force of equal magnitude but in the opposite direction.
kuruman said:
You are correct. The number is 2. Newton's 3rd Law says that forces come in pairs, so if you have a single force acting on an object (as in a free body diagram), you can safely deduce that there is another object (somewhere in the Universe and outside you free body diagram) that experiences a force of equal magnitude but in the opposite direction.
Ahh. Awesome. Thanks for your help!
  • · Replies 16 ·
  • · Replies 19 ·
