Find Equilibrant Force Using Trig Method
  • Thread starter Thread starter nikmar
    Force
To find the equilibrant force using the trigonometric method, first calculate the resultant force for each force system by summing the components of the individual forces. For example, in system A, the resultant force R is calculated as R = 5N at 0 degrees plus 5N at 90 degrees, resulting in a vector of 5i + 5j. The equilibrant force is then equal in magnitude but opposite in direction to the resultant force. This method applies similarly to the other systems, requiring the calculation of their respective resultant forces. Understanding this approach allows for the determination of the equilibrant force effectively.
nikmar
force system a:
force no. 1: 5.0N at 0 deg
force no. 2: 5.0N at 90 deg
force system b:
force no. 2: 5.0N at 60 deg
force system c:
force no. 1: 5.0N at 30 deg
force no. 2: 5.0N at 150 deg
how do you find the equilibrant force using the trigonometric method? Do you multiply the force 1 (5.0) times cos 0 deg; force 2 (5.0) times cos 90 deg; etc?:confused:
Well, you have a few systems consisting of two forces here. Now, for every system, i.e. for every couple of forces, you must consider the resultant force, which is the sum of the two forces of a system. For example, for the system a, you have \vec{R}=\vec{F}_{1}+\vec{F}_{2}=5\vec{i}+5\vec{j}. So, the force which will set the system of equilibrium is a force with the same magnitude as the resultant force R, but pointing in the opposite direction. Now you have a clue.
Thank you for your input...I think I have it.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
