Can Jet Engines Run Without Gasoline?
  • Thread starter Thread starter BigFly
    Engines Jet
Jet engines primarily operate on fuels similar to kerosene, not gasoline, due to gasoline's volatility and explosive potential. Alternative fuels, such as hydrogen, are possible, but they require specific adaptations for effective use. Research into fuel additives, like boron, has explored ways to enhance performance, although practical implementation has faced challenges. The efficiency of jet engines is influenced by the energy content of the fuel used, similar to internal combustion engines. Water injection can also be utilized to improve performance, demonstrating the ongoing innovation in fuel technology for aviation.
BigFly
I don't know a lot about jet engines and how they exactly work but is it possible to run a jet engine without gasoline? Are there any different fuels that can be used for the engine to give more propulsion or give it more time in the air?
Typically jet engines do NOT run on gasoline. They burn something close to kerosene.
Without a fuel, there is nothing in the cycle that would really accelerate the flow through the engine. You have to have some kind of energy source.
You wouldn't want to play around with gasoline in a turbine. It has a tendency to explode. It's too volatile. The fuels arena is a very active area of research. The current state of the art really has different fuels with different energy contents and operational parameters to allow the particular vehicle to operate in its required regime. It does play a role in overall efficiency. However, like the internal combustion engines in cars, one runs into the same problem of finding anything better in terms of energy content per unit mass of fuel.
you can run a jet engine on hydrogen as a fuel source
As said you need a fuel, however you can use water to increase performance. Google water injection.
Gas Turbines work very similarily to your car's engine, except certain steps happen at constant pressure rather than volume and vice versa, and of course it's continual.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
