How Do You Calculate Tire Pressure Without a Gauge?
  • Thread starter Thread starter Jeff231
    Pressure Tire
To calculate tire pressure without a gauge, one can use the car's weight and the dimensions of the tire in contact with the road. The total force on each tire is derived from the car's mass, divided by four since each tire supports an equal portion of the weight. The area of contact can be calculated using the tire's width and the length of the flattened segment. Density is not required for this calculation; instead, focus on the force and area to find pressure using the formula P = F/A. This method provides a reasonable estimate of tire pressure based on the available information.
Jeff231
"A friend asks you how much pressure is in your car tires. You know that the tire manufacturer recommends 30psi, but it's been a while since you've checked. You can't find a tire gauge in the car, but you do find the owner's manual and a ruler. From the owner's manual you find the car's mass is 1500kg. It seems resonable to assume that each tire supports one-fourth of the weight. With a ruler you find that the tires are 15cm wide and the flattened segment of the tire in contact with the road is 13cm long. What answer do you give your friend?"
P = Po + (density)gd d=depth
P= F/A
density(rho) = m/v
I know the force is 1/4(9.8)(1500).
I know Po is just the outside pressure (constant).
I'm confused on how density plays in the this equation/question. Also the area, A I'm confused how it's possible to find the area of the tire with just knowing how wide the tire is, how much ground is touching the tire, without knowing the sidewall height. It's not like the whole thing is made of tire, unless I'm suppose to assume there's no wheel?
Thanks.
You don't need to know the volume of the tire, just the change in volume due to the weight of the car - assume the tire would be round if the weigth of thecar was removed.
