What Is the Ratio of Charges q2 to q1 Based on Their Electric Field Angles?
  • Thread starter Thread starter jamiewilliams
    Charges Ratio
The discussion revolves around calculating the ratio of two positive charges, q2 to q1, based on the angles their electric fields make at the center of a circle. The net electric field is observed to make an angle of 28.6° with the vertical axis, while the charges are positioned at 30° and 60° from the vertical. Participants suggest using trigonometric functions to resolve the electric field vectors into their x and y components. A key insight is that the electric field vectors from the charges are at right angles to each other, which can help in determining the resultant angle. The correct ratio of q2 to q1 is identified as 1.64.
jamiewilliams
The drawing shows two positive charges q1 and q2 fixed to a circle. At the center of the circle they produce a net electric field that makes an angle 28.6° with the vertical axis, measured counterclockwise. Determine the ratio q2/q1.
[the drawing shows a circle with two charges: q1 measures 30° from the vert and q2 (on the other side of the vertical axis) measures 60° from the vert]
Coulomb's Law
First I sketched the situation and drew 2 vectors coming from the origin for the energy fields E1 and E2 (from q1 and q2, respectively). I drew the x and y components of each vector using trig functions. I think I am on the right track but I am stuck! No matter how I move around the equations and/or algebra I can't seem to get the right answer.
[correct answer is 1.64]
Coulomb's Law
Your description is a bit vague about where the angles are being measured from (with respect to the positive or negative y-axis?), but I think I've managed to come up with a diagram that fits the bill:
You might want to take note of the fact that the two lines that converge on the circle center from the charges happen to meet at a 90° angle, thus the electric field vectors from the charges will also be at right angles to each other at the center. You should be able to use that fact and your given angle for the resultant to determine the angle that the resultant makes with one or the other of those lines. That angle will then be related to the magnitudes of the field vectors...
