Is there a relativistic version of the work-energy theorem?
jaketodd
The work-energy theorem is stated here on Wikipedia. On the same page it says "regardless of the choice of reference frame, the work energy theorem remains valid and the work done on the object is equal to the change in kinetic energy."
I am wondering if there is a relativistic version of the work-energy theorem.
Thanks,
Jake
No. The classical version applies to relativity too. But the result is different.
W=\Delta E_k=(\gamma -1)mc^2
Just integrate force over some distance, starting from rest:
W=\int Fdx=\int \frac{dp~dx}{dt}=\int vdp=vp-\int pdv=\gamma mv^2-\int \gamma mvdv
What you end up with is:
W=\gamma mc^2+C
with some constant of integration C. If you set v=0, you take W=0 and γ=1, therefore C=-mc2. So what you get is:
W=\gamma mc^2-mc^2=(\gamma -1)mc^2=E_k
In general, W=\int F dx, but the Lorentz transformations tell you the relationship between dx in the two different inertial frames as dx = {{dx'}\over{\sqrt{1-{{v^2}\over{c^2}}}}}.
Two different inertial frames?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
