What does the bi stand for in bicarbonate, what is the purpose?
  • Thread starter Thread starter Sqw
The discussion centers on the chemical composition and nomenclature of bicarbonate, specifically its relationship to carbonate ions. Bicarbonate, or hydrogen carbonate, is identified as a compound that includes one carbon atom with an attached proton (H+). The term "bi" in bicarbonate is debated, with some suggesting it indicates the compound's ability to produce twice as much CO2 compared to carbonate, as seen in the example of sodium bicarbonate (NaHCO3) versus sodium carbonate (Na2CO3). The conversation also touches on the prefixes used in chemistry, such as mono, bi, di, and tri, which denote quantities of atoms in compounds. Overall, the thread clarifies the chemical structure of bicarbonate and its historical naming conventions.
Sqw
There's only one carbon atom...
Chemistry news on Phys.org
It just refers to the fact that it's a carbonate ion with an H+, essentially a proton, attached to it. I'm not sure where 'bi' comes from, but that's the reason why bicarbonate is also sometimes called hydrogen carbonate.
I think it's a compound consisting of 2 carbon atoms. Yep, they are the same Carbon - 12 atoms.
I usually use this which helps me a lot :
Mono - stands for one ( sometimes not mentioned like in maths ;) )
bi - stands for two
di - stands for two
tri - stands for three
Source : http://en.wikipedia.org/wiki/Bi-
Make sure you read it :)
Welcome to PF!
Hi Sqw! Welcome to PF! :smile:
I think it predates the modern understanding of molecules, and was because a bicarbonate contains twice as much carbon (ie it produced twice as much CO2) as the carbonate of the same metal.
eg NaHCO3 contains twice as much C per Na as does Na2CO3
since the latter is obviously a carbonate, the former must be a bicarbonate! :biggrin:
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
