Easy questions, A ball is shot out from a launcher, what is the acceleration?
The discussion revolves around the acceleration of a ball shot from a launcher, with participants debating whether the acceleration is zero, constant, increasing, or decreasing. The consensus is that once the ball is in motion, it is only influenced by gravity, which provides a constant acceleration of 9.81 m/s² downward. Some participants mistakenly believe that acceleration could be zero or increasing, but the correct understanding is that it remains constant due to the force of gravity acting on the ball. The confusion arises from the ball's horizontal launch, but gravity's effect is always downward and constant. Ultimately, the acceleration of the ball is constant as it falls.
nchin
A ball is shot out from a launcher as shown in the figure.
http://insight.ccsf.edu/file.php/4576/Lab_7_Prelab_Q1.JPG
(The picture is a ball being shot from a canon from on top of a building going down)
The acceleration of the ball is
a. zero
b. constant
c. increasing continuously
d. decreasing continuously
i just want to make sure, the answer is a) right??
I can't open the pic, but once an object leaves the cannon, and in the absence of air resistance, it is acted on by the force of gravity only. Why do you say the acceleration is 0?
accel. is zero because since only the force of gravity is acting on it then it does not speed up or slow down so it is zero. am i right??
I can't see the picture as you need a log on but,
acceleration due to gravity is 9.81ms-2
therefore it must be increasing constantly as it falls, when the ball reaches maximum height acceleration is 0 for an instant
No. If an object is subject to a net force, it must accelerate in the direction of the net force, per Newton's 2nd law, F_net = ma. The net force here is the object's weight , acting down, mg, where m is the mass of the object and g is the acceleration of gravity. So mg = ma. Is the acceleration, a, constant, increasing, or decreasing?
i chose the answer is c. increasing continuously, but it is incorrect...so I am leaning more towards accel is either constant or zero. The ball is shot horizontally by the way.
Why do you think its c? The force acting on the ball is always the force of gravity (even if its shot horizontally) which is constant.
im just listening to what Johnahh said "therefore it must be increasing constantly as it falls, when the ball reaches maximum height acceleration is 0 for an instant"
Ask yourself, is that correct? Read carefully PhantomJay's post.
ah i see since mg = ma then it should be constant right?
What do you think? If i answer that, i solve your homework.
thanks pranav!
