Several questions involving a homemade miniature jet engine.
A newcomer to engineering seeks guidance on building a homemade miniature jet engine to enhance their understanding of physics. They inquire about the functioning of a typical jet engine compressor and the best type of compressor for a small engine measuring 20cm wide and 50cm long. The discussion suggests researching designs for model jet engines and exploring patent processes for further insights. Participants emphasize that creativity and experimentation are key components of engineering. Overall, the conversation focuses on foundational knowledge and practical resources for jet engine construction.
metameta
Hey guys. I am new to engineering and I came to this because I wanted to make my own miniature jet engine. I have a limited knowledge of physics but I wish to broaden it through this idea.
Now I know that this was made before for RC models, but I want to actually make one so I understand how they work, and I decided to start here.
Here are my questions:
1. How exactly does a typical jet engine compressor work?
2. I believe there are several types of compressors used in jet engines. If I want to make one for a small sized engine, say, about 20cm wide and 50cm long, which type of compressor works best, and which factors define it?
Can anyone help?
Try googling "designs for model jet engines" there seems to be a lot of information out there.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
