What is the value of r given the change in electric potential?
The electric potential at a distance r from a positive point charge is initially 45V and increases to 50V when the distance decreases by 1.5m. The correct value of r is determined to be 15m. The discussion emphasizes using the equation V=(1/4∏ε) q/r and suggests taking the ratio of potentials to simplify the problem. Participants provide algebraic guidance to eliminate unknowns and solve for r. The final consensus confirms that the calculated answer is mathematically sound.
mrcotton
The electric potential at a distance r from a positive point charge is 45V. The potential
increases to 50 V when the distance from the charge decreases by 1.5 m. What is the
value of r?
A 1.3m
B 1.5m
C 7.9m
D 15m
the answer is D
V=(1/4∏ε) q/r
v proportional to 1/r
5=(q/(1/4∏ε))*((1/r-1.5)-(1/r))
How embarrassing I just can’t get my head around this one. Am I setting the equation up correct to solve.
If I have I need desperate help with the algebra.
Thank you
value of r?
A 1.3m
B 1.5m
C 7.9m
D 15m
the answer is D
V=(1/4∏ε) q/r
Thank you
You have one equation and two unknowns.
Taking the ratio \displaystyle \ \ \frac{V(r)}{V(r-1.5)}\ \ might be more helpful.
Otherwise, use your equation along with \displaystyle \ \ V(r)=45=\frac{q}{4\pi\epsilon_0\,r}\ \ then eliminate q & solve for r.
You're going to want to get rid of the constants you don't have values for (like the charge value q) so you'll probably want to set it up as a ratio so that they'll cancel out.
EDIT: SammyS got their first!
Thank you guys.
I did it like this with your help.
Is this mathematicaly sound.
Thanks
Mr C
mrcotton said:
Thank you guys.
Is this mathematically sound.
Thanks
Mr C
That answer is correct.
