Calculating Speed and Max Transverse Velocity of a Transverse Wave
The discussion revolves around calculating the properties of a transverse wave represented by the equation y = 2.28sin(0.0276pi x + 2.42pi t). The amplitude is confirmed as 2.28 cm, the wavelength as 72.46 cm, and the frequency as 1.21 Hz. The speed is calculated correctly at 87.68 cm/s, but there is confusion regarding the maximum transverse speed. It is clarified that the maximum transverse speed can be determined using the formula -wA when the cosine function equals 1, leading to a better understanding of the relationship between wave properties and their calculations.
croyboy
Please help!
Having a little difficulty with a homework question and concept
Find the amplitude, wavelength, frequency, speed and maximum transverse speed.
Definitely correct answers
A = 2.28cm
Wavelength = 72.46 cm
Frequency = 1.21 Hz
Questionable answers
Speed = 87.68 cm/s
Max transverse speed = ?
Reasoning
The speed should be w/k which would give 2.42pi/0.0276pi = 87.68 cm/s
The max transverse velocity though...would that be when the trig function of cos is equal to 1 in this equation u = -wAcos(kx-wt) ?
The speed is correct. Transverse speed is when dy/dt is a max. I think you are pretty much nailing that as well.
Apologies...still not quite sure...would I use the w and A i know multiplied with cos(kx-wt) to get my answer...so if cos(kx-wt)=1, then max transverse speed would be -wA?
If your displacement function is a sin wave, it's not possible that your velocity "function" be a constant of 87.68cm/s as you calculated. Your speed would be a function as well.
As you know, velocity is the change of displacement over time (i.e. dy/dt), so by differentiating the function for y, you will get a the velocity function (which in this case is a cosine function). That cosine function will allow you to calculate the speed at any location x and time t.
To calculate the maximum speed, we take a look at the velocity function. If you do your calculus right, the equation should look something like:
v = B cos (Cx + Dt)
There is an infinite possibility for the values of x and t, so we can assume that hthe cosine can return any value. The maximum value however of a cosine function is 1. So what does that tell you about your maximum velocity?
Yes. Except I'd call the maximum speed +wA. Why would you say minus?
Thanks much...makes a lot more sense...appreciate the help
