General Relativity Basics: The Principle of Equivalence
  • #51
JDoolin said:
I guess I've never been quite comfortable with the difference between "potential" and "potential energy"
"potential energy" has units of kg \frac{m^2}{s^2} and, if I'm not mistaken, "potential" doesn't get introduced until it is introduced as "electric potential" with Coulomb's Law in most introductory physics books.
I agree "potential" by itself is kind of a vague term, it gets used in a number of different ways. It would probably be better if relativity texts stuck to the term "energy per unit mass", which is what "potential" usually means when gravity is the only force under consideration, but which generalizes nicely to situations where other forces are in play without changing its meaning. Energy per unit mass also has the nice property that in "relativistic units", where the speed of light = 1, it is dimensionless.
JDoolin said:
Now I need to find the quantitative relationship between those two times.
One fairly easy way to do it is to transform to Rindler coordinates, as described in the Wikipedia page:
http://en.wikipedia.org/wiki/Rindler_coordinates
In these coordinates, the hyperbolas you've drawn become lines of constant x, and the lines AB and CD become lines of constant t. Once you write the metric in those coordinates, it's easy to calculate the times AC and BD, since each of them are measured along lines where only one coordinate changes (the Rindler t, in this case), so only one term in the metric is relevant.
  • #52
Forgive me for nitpicking, but resolving to 1 does not mean "dimensionless." It just means that the correlation coefficient comes out to be 1.
Me being totally of topic said:
You might have c=1 ly/y, or c= 1ls/s. The unfortunate fact is that we don't have any word that sounds intuitively like a distance that makes the speed of light = 1. The closest I've been able to come is 1 foot/nanosecond, which is close to the speed of light.
I do believe that it is nice when quantitities come out to be 1, but even when this happens, the units are still important.
Little things you notice after teaching introductory physics for a couple semesters: For instance, Kepler's Third Law is
\frac{T^2}{r^3}=\frac{4 \pi^2}{G M_{sun}}​
which becomes
\frac{T^2}{r^3}=1 year^2 / AU^3​
if you use units of Astronomical Units for r and Years for T.
This is getting off topic, but I don't really "believe" in dimensionless quantities, even when they come out dimensionless. The coefficient of friction is not unitless, but Newtons/Newton. i.e. Newtons of frictional force per Newton of parallel force.
On the other and if you take Torque, and divide by Work, you get a unitless quantity, but as far as I know, there's really no physical application of this at all. Work involves a dot-product of F*d and torque involves a cross-product of F*d. The directions of the force and distance make these two quantities completely conceptually different, even though they happen to have the same units.
Then there's the whole discussion of radians and degrees, which in some way measure the portion of a circle. They should have some kind of exact analogy in rapidities. If anything could convince me to "believe" (so to speak) in dimensionless quantities, it would be angles and rapidities.
I'm looking over the Wikipedia article. Now a couple of vaguely coherent thoughts are coming to mind.
they use t to represent the time according to one of the accelerated observers whose acceleration g=1. Off the top of my head, I'm thinking 1 ly/year^2 and 1 ls/s^2 are different quantities; but I'm not sure. I am calling this observer whose acceleration is g=1 the "reference observer"
I would prefer to see the equation relating tanh(t)=T/X with all of the variables, (a, c or r=c2/a) still present.
The value for t does not represent what any clocks would say, (except for the reference observer whose g=1). I'm not sure what notation, exactly, I'm looking for to find the relative speed of the clocks. (the issue might be entirely resolved if we have the equation with a and c or r=c2/a)
Finally, it may be interesting to note, precisely, the relationship between the reference-observer's passage of time, and his rapidity.
  • #53
Yes, 1 ly/y^2 and 1 ls/s^2 are different quantities; 1 ly/y and 1 ls/s are the same velocity, but when you divide that by 1 y you get a different acceleration than when you divide it by 1 s--the latter is a much larger acceleration (about 30 million times larger, since that's the number of seconds in a year).
The "relativistic units" they're using express everything in terms of length, so converting back to conventional units just means replacing every time t with ct and every acceleration a with a / c^{2}, then canceling c's where possible (and rearranging so the c's don't appear in front of the t's, if desired). I come up with:
t = \frac{c}{g} arctanh \left( \frac{cT}{X} \right), x = \sqrt{X^{2} - c^{2}T^{2}
T = \frac{x}{c} sinh \left( \frac{gt}{c} \right), X = x cosh \left( \frac{gt}{c} \right)
ds^{2} = - \frac{g^{2} x^{2}}{c^{2}} dt^{2} + dx^{2} + dy^{2} + dz^{2}
That's what the metric, ds^{2}, tells you. The observers in question all have constant x, y, z, so the only non-zero coordinate differential along their paths is dt. That means their proper time, which is just \sqrt{- ds^{2} / c^{2} }, is given by
\tau = \frac{gx}{c^{2}} t
  • #54
I feel compelled to make up another table:
<br /> \begin{center} \begin{tabular}{| c | c | c | }\hline <br /> Quantity &amp; Circ &amp; Hyperbola \\ \hline<br /> Unit Circle/Hyperbola &amp; X^2+Y^2=1 &amp; X^2-(cT)^2=\left(\frac{c^2}{a} \right)^2 \\ \hline<br /> Circle &amp; X^2+Y^2=r^2 &amp; X^2-(cT)^2=x^2 \\ \hline<br /> Vertical Component &amp; Y=r sin(\theta) &amp; c T=x sinh \left(\frac{a t}{c}\right) \\ \hline<br /> Horizontal Component &amp; X=r cos(\theta) &amp; X=x cosh \left(\frac{a t}{c}\right) \\ \hline<br /> Arc Length/Proper Time &amp; \Delta s = r \theta &amp; c \tau = x \left(\frac{a t}{c }\right) \\ \hline<br /> <br /> \end{tabular}\end{center}​
In this, it appears that t takes on the role of an angle (the time passed by the accelerated observer at x=c^2/a) , while x is analogous to the role of a radius (the distances from the rindler horizon as observed by the accelerated observers) A major difference, I think, is that while arc-length increases happily with both X and Y, proper-time goes up by cT and down by X.
I know \theta represents the arc-length divided by the radius; which seems a perfect geometric description of the angle. However, I don't know if at/c has such an easy relationship*. I know of a geometric analogy between polar angle and hyperbolic angle which is shown http://en.wikipedia.org/wiki/File:Funhipgeom.png" and I went ahead and attached it. (*Never mind, Actually, it has basically the same relationship. at/c = c tau / x. theta = Delta s / r.)
  • #55
JDoolin said:
I know \theta represents the arc-length divided by the radius; which seems a perfect geometric description of the angle. However, I don't know if at/c has such an easy relationship.
Obviously it does, since your last formula says that at / c is the arc length c \tau (which is the proper time converted to units of length) divided by the radius x.
Also, the slope of the line of simultaneity through a given point on the hyperbola (meaning the line through the origin that also passes through that point), which is just the boost velocity at that point, relative to the global inertial frame, is given by
\frac{c T}{X} = \beta = tanh \left( \frac{a t}{c} \right)
So I think we can equate at / c with the rapidity.
  • #56
\begin{center} \begin{tabular}{| c | c | c | }\hline Quantity &amp; Circ &amp; Hyperbola \\ \hline<br /> <br /> radius, proper distance &amp; X^2+Y^2=r^2 &amp; X^2-(cT)^2=x^2 \\ \hline<br /> <br /> Unit Circle/Hyperbola &amp; X^2+Y^2=(l_u)^2 &amp; X^2-(cT)^2=\left(\frac{c^2}{a_u} \right)^2 \\ \hline<br /> <br /> Arc Length/Proper Time &amp; \Delta s = r \theta &amp; \Delta\tau = \frac{x\phi}{c} =\frac{x a_u t}{c^2}\\ \hline <br /> <br /> <br /> Angle/Rapidity &amp; \theta= \frac{\Delta s}{r}=arctan(Y/X) &amp; \phi = \frac{a_u t}{c}=\frac{c\Delta\tau}{x} =arctanh(cT/X)\\ \hline<br /> <br /> Vertical Component &amp; Y= r sin(\theta) &amp; c T=x sinh (\phi) \\ \hline<br /> <br /> Horizontal Component &amp; X= r cos(\theta) &amp; X=x cosh (\phi) \\ \hline<br /> <br /> \end{tabular}\end{center}​
Some further observations:
  • The passage of proper time is affected signifcantly, as a function of proper distance, x and [strike]rapidity[/strike] acceleration.
  • The distances x are exactly the same as in the inertial frame. i.e. the rindler coordinate system does not have any effect on the measurement of proper length.
  • I have replaced 1 with lu, and a with au to denote a unit length and a unit acceleration. The unit circle is a different entity depending on whether you use feet, meters, etc. The unit hyperbola will also be different depending on what units you use.
I think I'm now ready to apply the equivalence principle to this system. From the perspective of the accelerated body, if I'm not mistaken, it would look like g->infinity as x->0, and g->0 as x->infinity. Potential energy would be determined as Work=Force*distance; "Plain Potential" would be Work/mass=acceleration * distance. Especially of interest is to determine g(x) , U(x), and d \tau(x)/d T.
Once I understand how the relationship between time-dilation and potential energy is found in this system, I may begin to understand the relationship between time-dilation and real gravitational potential energy.
  • #57
I'm not sure this is completely correct. I agree that in the metric for Rindler coordinates that I quoted above, the metric coefficient for all the space coordinates is 1, meaning that observers at constant x, y, z coordinates will observe a constant spacelike interval ds between each other along curves of constant Rindler time t. However, the physical meaning of this is a little more complicated. The Wikipedia page I linked to in an earlier post discusses various physical notions of "distance" that do not all give the same answers in Rindler coordinates, whereas they do in, for example, global inertial coordinates such as the T, X we are using for the global inertial frame.
I haven't gone back and checked earlier posts in this thread, so I don't know if this has been brought up before, but what you're contemplating here goes beyond the equivalence principle. (Which doesn't mean that what you're contemplating is not of interest or worth doing.) The equivalence principle only applies locally; more precisely, it only applies over a small enough region of spacetime that tidal gravity can be neglected. Of course in Rindler coordinates, which are coordinates on flat spacetime, tidal gravity is zero everywhere; but the spacetime you'll be comparing them to, presumably Schwarzschild coordinates outside a gravitating body, is *not* flat, so you'll have to restrict your comparisons to a region of that spacetime that's small enough to set up a comparison with a region of Rindler coordinates. The exact size of that region will vary with the specific case; but certainly looking at what happens as any quantity of interest goes to infinity will *not* fall within a small region.
One example of how global comparisons break down between these two systems is the following: consider two observers accelerating at 1 g, one on a rocket out in deep space, the other standing on the surface of the Earth. Both observers launch an object straight up (i.e., in the direction they are accelerating) at "escape velocity", 11 km/s. The observer in the rocket ship will eventually catch up with the object and pass it. The observer on the Earth will see the object recede forever. Yet these observers are equivalent as far as the equivalence principle is concerned.
  • #58
The distances in x, and the values of X match at time T=t=tau=0. I think the wikipedia article refers to this as the "ruler distance"
These other notions of distance are interesting, too. I strongly suspect that if you were looking up, the same ruler-distances would look further than the same ruler-distances looking down. However, if you consider the radar-distance; timing a signal as it takes to reflect back. The radar distance would appear further going down then up than going up then down. Since the further apparent distance results in a shorter radar-distance, that seems a bit counter-intuitive; I may have to do some math to verify that.
In "comparing" an infinite uniform gravitational field to a real gravitational field, I meant to highlight the differences; not just the similarities. You make an excellent point, bringing up tidal gravitation; if I'm not mistaken, this is dg/dr. However, notice that we have established that the rindler coordinates also has a nonzero dg/dx, since the born rigid system must have different accelerations at different ruler distances.
  • #59
I think I can establish that in the inertial frame, the structure's acceleration at any given point X, at T=0 is given as:
g(X)=\frac{c^2}{X}​
I think this is the value of
g(X)=\frac{d^2 X}{dT^2}​
Where (X,T) represents the path of a particular accelerated object.
However, what is the appropriate value of the gravity g(x) in the accelerating frame? We want to use the local time tau, instead of the inertial coordinate time T.
g(x)=\frac{d^2 x_{obj}}{d \tau^2}​
We need to consider not dx, because in the accelerated frame, x is the ruler distance, which is not moving. Instead we need to consider the position, xobj, of something that is stationary in the inertial frame, but it's position will change relative to x over time.
I'm kind of speculating that once we account for this, we'll find that the measured gravity will be the same for everybody on board the rocket, even though it looks like different accelerations to the inertial observer.
However, since tau gets faster and acceleration gets slower as you go up, I think it won't come out so nice. Or maybe it will. I'm not working through it real clearly just yet.
  • #60
Not quite. It's true that, for the particular case we're considering, the Schwarzschild spacetime outside a gravitating body, the tidal gravity happens to equal dg/dr; but that's not true in general, and the fact that dg/dx is also nonzero in Rindler coordinates does not mean that there is nonzero tidal gravity in flat spacetime (which is what Rindler coordinates apply to).
The general rule is that "tidal gravity" is just another name for "spacetime curvature"; so tidal gravity is only nonzero if spacetime is curved, which it is outside a gravitating body, but is not (obviously) in flat spacetime, even for accelerating observers. Mathematically, tidal gravity/spacetime curvature is quantified by the Riemann tensor and various other tensors formed from it. In flat spacetime the Riemann tensor is zero everywhere; if we were to calculate its components in Rindler coordinates that's what we would find. In Schwarzschild spacetime, the particular component of the Riemann tensor that gives what we've been calling dg/dr is R^{r}_{trt}, which, when you work through the math, turns out to equal dg/dr. (Actually, it may only equal dg/dr for r much greater than the Schwarzschild radius, which of course it is for the cases we've been considering; for values of r close to the horizon, there is an extra factor in the denominator in the formula for g, which makes it diverge to infinity at the horizon, but all the Riemann tensor components are finite and well-behaved at the horizon. I'll have to go back and check the exact formulas.)
  • #61
Actually, what we established was that there was a nonzero dg/dX when g was based on the acceleration in the inertial frame. But because the rate of proper time \tau is different at those different x values, this means that in the accelerated frame, the local value of g is also different at those different x values.
Instead of
g(x)=\frac{d^2 X_{rocketfloor}}{d T_{inertialclock}^2}​
we want:
g(x)=\frac{d^2 x_{inertialobject}}{d \tau_{rocketclock}^2}​
Whether we claim zero tidal gravity, or not, I think it is important to explicitly define our variables. In the rindler coordinates, neither dg/dr, nor dg/dx are sufficient, because g is a function of the local rate of time.
I thought it was obvous that spacetime was flat, even for accelerating observers, but now we have this nonzero dg/dX in the inertial frame which means it is no longer obvious that dg/dx is zero in the accelerated frame.
  • #62
I think it will indeed turn out when you do the computation you describe in post #59 that dg/dx will *not* be zero in the accelerated frame. The reason is simple: observers at different Rindler coordinates x certainly *feel* different accelerations, and that's what the function g(x) is supposed to capture--the acceleration that an observer at a given x *feels* (would measure with an accelerometer, etc.). So I expect g to vary with x.
But even assuming this is true, as I said before, it does *not* mean that the spacetime is curved. You can't change flat spacetime to curved spacetime by changing your coordinate system (or your state of motion); whether spacetime is flat or curved is a geometric invariant, just like the curvature of the Earth's surface. If you want, we can verify this by explicitly computing the components of the Riemann tensor in Rindler coordinates and verifying that they are all zero (or maybe a kind soul will point us to someplace where that computation has already been done).
  • #63
I think I have a possible approach to the problem, somewhat inspired by your earlier reference to Misner Thorne Wheeler. To find the "gravity" measured by occupants of the rocket at any given x, we can use a diagram similar to the one attached, and use
(x_2 - x_1) = \frac{1}{2} a \tau ^2
I think that \tau is fully determined by x1 and \Delta x, so we should be able to find an explicit value of a for any given x.
That would be fine, I suppose, with the caveat that I'm effectively tensor illiterate. I got an MS degree in math and physics, but none of my professors ever talked about tensors. PS, I have looked at a few of the Susskind lectures on YouTube, and I am at least skimming MTW, and Wald now, but so far, it's all a little too abstract for me.
  • #64
Newtonian equation motion in a gravitational field, written in full:
(Inertial mass) * (Acceleration) = (Intensity of gravitational field) * (Gravitational mass).
It is only when there is numerical equality between the inertial and gravitational mass that the acceleration is independent of the nature of the body. This is the Principle of Equivalence, which has double meanings.
Reference: The Meaning of Relativity, Albert Einstein.
  • #65
You don't have to be. You understand the concept of spacetime and the geometric invariant ds2. All that's needed is to make the leap to curved spacetime, where one *must* use covariant *and* contravariant components to define a geometric invariant.
I tried to explain this in post#9 and #11 in this thread https://www.physicsforums.com/showthread.php?t=431843
Do dimensional indexes throw you, i.e. writing t as x0, x as x1, y as x2 and so on ? Or the summation convention xaxa=x0x0+x1x1+x2x2+x3x3 ?
If you hate all the indices try the diff. geom. approach.
  • #66
I read discussions under General Physics, Classical Physics, and Specia Relativityl & General Relativity. I THINK there are several slightly varying interpretations of mass, force, accelaration, gravity, etc.
Gamow's One, Two, Three, Infinity raised my curiosity well enough to help me decide to become a physicist. Universities turned me into a marching physicist. Wigner's Symmetries and Reflections made me a humble physicist. I strongly recommend Wigner's essays. What an insigthful book!
  • #67
Well, I think I've come to a conclusion; right now, the result seems surprising to me, but probably won't to you.
\begin{matrix}<br /> x cosh(\phi)=x+h \\<br /> \phi=arccosh\left ( \frac{x+h}{x}\right )\\<br /> \Delta \tau = \frac{x \phi}{c}\\<br /> a = \frac{2 h}{\Delta \tau^2}\\<br /> a=\lim_{h \to 0}\frac{2 h c^2}{x^2 ArcCosh^2(\frac{x+h}{x})}=c^2/x<br /> \end{matrix}​
(The attached diagram might help.)
It comes out so whether you do the calculation by (X and T) or by (x and \tau), you get the very same result for the acceleration.
  • #68
General relativity has it that the spacetime continuum is curved. The physics of continuum is dealt with [stress] tensors.
My questions:
(1) The presence of a mass creates the curvature. By how?
(2) If the curvature due to matter is positive, is the sign due to antimatter negative?
(3) Do other fundamental interactions (the strong, the weak, and electromagnetic) create curvatures in their respective fields?
  • #69
My questions:
Do you want to start another topic with these questions - you are hijacking someone else's topic.
  • #70
I posted a reply (post 13) there in the other thread; yes I still want to understand tensors.
  • #71
This looks OK to me as a calculation of the acceleration (or rather a verification that the calculation gives the same results in the inertial frame and the accelerated frame). I assume you would then just take the derivative with respect to x to get dg/dx?
  • #72
Yes. I think that comes out to be
\frac{dg}{dx}=-\frac{c^2}{x^2}.​
http://groups.google.com/group/sci.physics.relativity/msg/6ff91383c387f7a1?hl=en" tidal gravity as a "divergence of free-fall paths." So is dg/dx the definition of tidal gravity? Could it be that what we have here is the divergence of free-fall paths caused by Lorentz contraction alone?
  • #73
JDoolin said:
URL="http://groups.google.com/group/sci.physics.relativity/msg/6ff91383c387f7a1?hl=en"]Daryl McCullough describes[/URL] tidal gravity as a "divergence of free-fall paths." So is dg/dx the definition of tidal gravity? Could it be that what we have here is the divergence of free-fall paths caused by Lorentz contraction alone?
No. The *free-fall paths* are not diverging; the *accelerated* paths are (actually, they're "converging" from the point of view of the global inertial frame, but converging is just "negative diverging", so to speak). The free-fall paths remain parallel (this is obvious in the global inertial frame); they don't converge or diverge. Hence, the tidal gravity is zero.
In the spacetime around the gravitating body, on the other hand, the actual free-fall paths converge or diverge; which they do depends on their relative orientation. For example, two free-fall paths separated radially will diverge (their separation will increase with time), while two free-fall paths separated tangentially will converge (their separation will decrease with time).
I realize that, as it stands, the above may not be very enlightening, because "separation", as it stands, is frame-dependent. After all, the accelerated observers see their own separations as constant, whereas inertial observers (in the flat-spacetime scenario, at least) see their separations as decreasing with time (due to Lorentz contraction). However, it turns out that there *is* an invariant way to define "separation" for *nearby* geodesics (free-falling paths): pick one free-falling path as the "origin" or "reference worldline", and construct a local inertial frame around it. Then the "separation" between the two free-falling paths is just the spatial distance between them in the local inertial frame, and the *change* in the separation is the derivative of that spatial distance with respect to proper time along the reference worldline. (Note that in curved spacetime, a "local" inertial frame must be "local" in time as well as in space, so actually, we have to construct a separate local inertial frame and go through the above procedure at each *event* on the reference worldline.)
If we do this for the accelerated paths in flat spacetime (the "Rindler worldlines"), we find that the "separation" x in Rindler coordinates does *not* meet the above requirements, so we can't use it to measure the "separation" we need to evaluate tidal gravity. Instead, we have to look at the free-falling worldlines themselves and construct local inertial frames around them. Of course in this particular case that's easy, because all of them are just the worldlines of objects at rest in the global inertial frame, which therefore qualifies as the "local inertial frame" for all of them (with the origin shifted appropriately, if you want to be precise), and all of them obviously maintain constant separation in that frame. So there's no tidal gravity.
In the curved spacetime around a gravitating body, on the other hand, we have to go through the full procedure I described above, and when we do, we find that the separations of nearby free-falling worldlines *do* converge or diverge as I stated above.
The technical term for the math behind the procedure I described above is "equation of geodesic deviation"; the sections on that subject in MTW or Wald are decent places to start if you want to study it further. However, their treatment requires full-blown tensor algebra. If I can find a discussion that's more oriented towards the physical aspects I'll post a link.
  • #74
I can't tell whether you are disagreeing with the physics, or just the words I am using.
Two stationary particles in the inertial frame will appear, in the rocket frame, to rise up from below, decelerating, and spreading out until they stop. Then they will appear to fall down, accelerating and contracting. Both the apparent spreading out, and the contracting are mathematically identical to what one would expect from Lorentz Contraction of a ruler placed between the two objects.
Do you disagree with this?
Edit: With one extra caveat--the top and bottom of any free-falling object will appear to be moving at different velocities. In general Lorentz Transformation alone means the front and back are moving at the same velocity
  • #75
I didn't understand the above requirements. When you say "the local inertial reference frame" are you referring to the momentarily comoving reference frame of the accelerating body? Of course that quantity doesn't change. That's kind of the point of Lorentz Contraction.
Possibly, we are talking about two different x's. You are talking about x's being drawn up on the side of the rocket-ship. I'm talking about the x coordinate of a free-falling body, as measured by the ruler drawn up on the side of the rocket ship.
  • #76
I don't disagree with the physics, but I do say that what you've described above is not "tidal gravity". The apparent spreading out and contracting in the rocket frame are, as you note, kinematic effects; we can transform them away by switching to the global inertial frame. Tidal gravity can't be transformed away by changing reference frames. See my next post responding to your next post.
  • #77
Sort of. The key thing is that, to measure geodesic deviation, you have to compare two nearby geodesics, and the worldline of an accelerating observer is not a geodesic. In the MCIF anywhere along the accelerating observer's worldline, you can pick two nearby geodesics and look at whether they converge or diverge as judged from the MCIF; but in doing that, you will have to look beyond the "momentarily comoving" part of the MCIF, because if you restrict yourself to the "momentarily comoving" part only, it by definition is too small to see tidal effects!
In the particular case we're discussing, suppose we pick the MCIF of the rocket at the instant when one free-falling object is momentarily at rest relative to the rocket (and at the same spatial point). That MCIF will then be the same as the rest frame of the free-falling object (which, since spacetime is flat in this scenario, is basically the global inertial frame), but it will only be "momentarily comoving" with the rocket in a very small patch surrounding the instant when the two objects are momentarily at rest relative to each other. Within that small patch, we can't tell if the spacetime is flat or curved (i.e., whether there are or are not tidal effects); but outside that patch, we can see that, in the inertial frame, the two free-falling objects maintain constant separation for all time, so there's no tidal gravity. We can't use their changing separation in the rocket frame for this purpose because the rocket frame doesn't "stay inertial" outside the small patch.
In the corresponding case in curved spacetime, if we again chose our MCIF the same way, the inertial frame of the free-falling object, *extended outside the small momentarily comoving patch*, would be our "local inertial frame" for measuring geodesic deviation. Then we would see that, *outside* the small momentarily comoving patch, the separation of the other nearby free-falling object would *not* remain constant--it would converge or diverge (depending on the direction of the separation), even as judged from the inertial frame. This is not a kinematic effect; it's a real, invariant convergence or divergence of the geodesics and can't be transformed away by changing reference frames.
  • #78
In the attached diagram I have plotted some worldlines of free falling particles (blue lines) near the event horizon in Schwarzschild coordinates. In these coordinates the particles seem to be initially diverging radially but as they approach the event horizon (vertical green line at r = 2m =1) they converge radially. (The red lines are the Fermi normal lines of the primary free falling observer which is indicated by the black boxes at the intersections.)
Are you saying that in the free falling frame the particles will appear to continue diverging according to the free falling observer as they approach and pass through the event horizon? It would be nice is someone could plot the free falling wordlines from the point of view of the free falling observer to prove that is the case.
  • #79
O.K. I think I have answered my own question. I have managed to plot the the worldlines of free falling observers (blue curves) in Gullstrand-Painleve coordinates in the attached diagram and they do indeed appear to diverge continuously as the event horizon is approached and continue to diverge after passing through the event horizon from the point of view of the free falling GP observers.
The green curves are ingoing null paths and the red curves are outgoing null paths. The event horizon is at x=2 in the diagram.
It can also be seen from the way the null paths have been plotted, that the radar distance between neighbouring free falling observers is continuously increasing as they fall.
If anyone wants the equations to plot these curves, just ask :smile:
  • #80
Yes, the equations would be nice. Plots (and even better animated plots) are extremely useful to get a quick overview of what an equation 'does'. In this day and age we have wonderful tools to visualize information and demonstrating something with a plot is an excellent means.
  • #81
There is no horizon at r=2m in the Painleve chart.
The metric is
\begin{align*}<br /> \left[ \begin{array}{cccc}<br /> \frac{2\,M}{r}-1 &amp; -\sqrt{\frac{2M}{r}} &amp; 0 &amp; 0\\<br /> -\sqrt{\frac{2M}{r}} &amp; 1 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; {r}^{2} &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; {r}^{2}\,{sin\left( \theta\right) }^{2} \end{array} \right]<br /> \end{align*}<br />
Note the flat spatial sections.
An observer at rest wrt to the 'rain', will see tidal tensor with T_{rr}=2m/r^3,T_{\theta\theta}=T_{\phi\phi}=-m/r^3
  • #82
This is not correct. The horizon is a frame-independent, invariant feature of the geometry, and it's there regardless of what coordinate chart you use. Yes, the spatial sections in the Painleve chart are flat, but that doesn't mean an observer at r < 2m can send signals to r > 2m. The curvature of the spacetime that makes that impossible is all in the "time dimension" (so to speak) in the Painleve chart, but it's still there.
Edit: Maybe what you meant to say is that there is no *coordinate singularity* at r = 2m in the Painleve chart?
  • #83
Yes. Thanks for the lecture, anyway.
  • #84
OK, here is how the equations to plot the paths in the https://www.physicsforums.com/showpost.php?p=2949294&postcount=79" were obtained.
The GP coordinates are given by Wikpedia as:
dt_{GP} = dt\, +(1-2m/r)^{-1} \sqrt{2m/r}\, dr
dr_{GP} = dr
Where dt and dr are the familiar Schwarzschild coordinates.
Now we know that the equation for a falling particle with apogee at infinity in Schwarzschild coordinates is dr/dt = -(1-2m/r)^{-1} (2m/r)^{-1/2} and we can substitute this equation into the definition of the GP time coordinate to elliminte dt and obtain:
dt_{GP} = - \sqrt{ \frac{r}{2m}}\, dr
(This turns out to be the same as the velocity measured by a local stationary Schwarzschild observer at r). Integrating the above gives the equation for the path of the falling particle in GP coordinates:
t_{GP} = -\frac{2r}{3}\sqrt{\frac{r}{2m}} +C
where C is a constant of integration.
Substitution of the GP time coordinate into the radial Schwarzschild metric gives the GP metric:
dtau^2 = (1-2m/r) dt_{GP}^2\, - 2\sqrt{2m/r}\, dr\, dt_{GP} \, - dr^2
Setting dtau = 0 gives the null path of a photon and solving the resulting quadratic gives the differential equation:
dr/dt_{GP} = (\pm 1)\, - \sqrt{2m/r}
where the sign is determined by whether the photon is ingoing or outgoing. For an ingoing photon the speed at the EH is -2c and the outgoing photon is zero.
Integrating gives the equations for the null paths in GP coordinates:
t_{GP} = r(2\sqrt{2m/r} \, \pm 1) - 4m\, \text{artanh}\left(1/\sqrt{2m/r}\right)\, \pm 2m \ln(r-2m) \, + C
or alternatively for the outgoing photon:
t_{GP} = r(2\sqrt{2m/r} \, +1) \, + 2m \ln\left((r-2m)\frac{1-\sqrt{2m/r}}{1+\sqrt{2m/r}} \right) \, + C
and for the ingoing photon:
t_{GP} = r(2\sqrt{2m/r} \, -1)\, - 2m \ln\left((r-2m)\frac{1+\sqrt{2m/r}}{1-\sqrt{2m/r}} \right)\, + C
The alternative form allows the null paths to be plotted across the event horizon without problems.
  • #85
The metric is
So the proper time of a particle in this region could be measured by:
<br /> ds^2=<br /> (dr^2<br /> -dt^2<br /> + r^2 d\theta ^2<br /> +r^2 \sin ^2 \theta d\phi ^2)<br /> +(\frac{ 2 M}{r}dt^2 <br /> -2 \sqrt{\frac{2 M}{r}} dr dt)​
This is the same as flat space except for the two terms at the end. Is this Painleve chart the same as the Schwarzschild metric?
What makes a heavy mass into a black hole is that it's own physical radius is smaller than its own horizon, right?
  • #86
I think a little more accurately stated:
An object becomes (or is already) a black hole if the ratio between the area it occupies and the area that represents its mass is smaller than 4. As soon as this happens the object's occupied area will shrink to zero.
E.g.:
<br /> {A_{occupied} \over A_{mass} } &lt; 4<br />
You notice that mass by itself is not in indication of whether something is a black hole or not, it is only the ratio that matters.
In general relativity mass is represented by a physical area.
Because spacetime is curved when we have mass it is no longer a trivial matter to derive a radius from those areas.
  • #87
I live on a rocket that is under constant acceleration.
The rocket has many floors. My floor is labeled x=9.18 \times 10^{ 15} m, and on my floor, the gravity is g=c^2/x.
If I climb up, the gravity gets smaller. If I look up, the clocks above me are ticking faster.
If I climb down, the gravity gets greater. If I look down, the clocks below me are ticking slower.
If I drop something out the window, it falls down, and approaches a point c2/g below, but it will never reach there. The clocks down at that level (x=0) are not ticking at all and nothing can fall past them. If the rocket extended down that far, the gravity there would approach infinity.
I still need to determine the speed of the clocks as a function of either g or x. Then answer the more ambiguous question, is the speed of time determined by gravitational potential?
  • #88
  • #89
An approximation follows:
We adopt a standard unit of time being the time it takes for an object to fall 1 meter. The following can only be used where x>>1, because when x is near or less than 1, the acceleration is not constant.
<br /> \begin{matrix}<br /> <br /> \Delta x = \frac{1}{2}g \Delta t^2 <br /> \\ \Delta t = \sqrt{\frac{2 \Delta x}{g}}= \sqrt{\frac{2}{g}}=\sqrt{\frac{2 x}{c^2}}<br /> \\ \frac{\Delta t(x)}{\Delta t(x_0)}=\sqrt{\frac{x}{x_0}}<br /> <br /> \end{matrix}<br />​
One interesting aspect of this is that the speed of time approaches infinity as x \to \infty. So as an ambiguous answer to my ambiguous question, the infinite speed of time would mean there is no natural zero for a corresponding gravitational potential.
  • #90
As soon as you drop something out of the window it is no longer in the accelerating frame you are describing but instead it is free falling and it keeps free falling forever.
Close to this region clocks run slower wrt clocks higher up but locally clocks just run as normal. Free falling objects would pass by without hindrance.
If I am not mistaken the relationship between proper time and coordinate time for a given acceleration is:
<br /> \tau={c\, \over \alpha} {\it arcsinh} \left( {\frac {\alpha t}{c}} \right)<br />
While the relationship between acceleration and position is:
<br /> \alpha={\frac {{c}^{2}}{x}}<br />
  • #91
  • #92
why didnt you give the link to the post?
https://www.physicsforums.com/showthread.php?p=2951148#post2951148
pervect said:
Gravitatonal time dilation is a REALLY BIG clue that space-time is curved. If you think of gravity as just being a force, there's no reason it should affect how clocks operate. But we observe that it does. Recent experiments can detect the gravitational time dilation for a height difference as small as a foot.
When we draw the resulting space-time diagram, we have diagrams that look like they should be parallelograms, but the sides are of unequal length. (The "sides" of unequal length in this diagram are the clocks which run at different length because it's a space-time diagram).
This isn't possible in an Eulidean geometry, and suggests (as most textbooks will mention) that space-time is curved.
To actually calculate a curvature invariant and show that it is nonzero is a bit more involved, but it's certainly possible in principle. It involves measuring the metric accurately enough to get the second partial derivatives. This will rule out some special cases such as being in an elevator. But basically, the reason we know that space-time is curved is that clocks appear to run at different rates depending on their gravitational potential[/color].
  • #93
why didn't you give the link to the post?
Because it's at the top of the page ( in my browser) and you get straight to it.
What are you ? The link police ? If you're going to nit-pick, at least choose something worth the trouble.
  • #94
it wasnt even on my page
it was on page 2
  • #95
it was on page 2
OK, sorry I snapped. But the link I've given is clearly to page 3. Anyway, I don't agree with everything in that post, I just thought the last sentence answered JDoolin's question.
Peace.
  • #96
I know that the link you gave was to page 3. But there are different display modes and for the display mode that I use the post that you intended to link to was on page 2.
  • #97
I was OK with your post up until this point. It would be OK to say that the rocket cannot extend to x = 0, but it is not OK to say that "clocks at that level are not ticking at all and nothing can fall past them". The reason is simple: if you drop something out the window, it *does* fall past "a point c^2/g below", and its clock continues to tick. However, even this way of stating it is, in my opinion, misleading, which is why I put the phrase "a point c^2/g below" in quotes.
Here's what I think is a better way to describe what's going on: consider a light beam emitted from the event x = 0, t = 0 in the global inertial frame (what I think we were calling the "lab frame" above, as opposed to the "rocket frame"). No observer on the rocket, on any of its floors, will ever see this light beam; it will never catch up to any portion of the rocket (assuming that the rocket, with all its floors, maintains its acceleration forever). This fact is what justifies us referring to the light beam's worldline--the line x = t--as a "horizon" with respect to the rocket. However, a free-falling observer who is dropped off any floor of the rocket *will* see this light beam, after a finite amount of proper time by the free-falling observer's clock. From the rocket's point of view, the free-falling observer's clock will *appear* to move slower and slower as the observer approaches the horizon, but no rocket observer will ever see the free-falling observer cross the horizon (because light rays from events on the horizon will never catch up to the rocket, as above).
(Edit: I should clarify the statement "the free-falling observer's clock will appear to move slower and slower". What I really should have said was that, if we imagine the free-falling observer emitting light beams at values of his proper time closer and closer to the proper time when he crosses the horizon, those light beams will reach the rocket at times, according to the rocket's clock, that increase without bound.)
This way of putting things also puts the "gravity approaches infinity as the horizon approached" statement into proper perspective. The horizon itself is a null surface--only light rays can move "on" the horizon, so there's no such thing as an observer that stays "at" the horizon, not even one with infinite acceleration (or infinite "gravity"). The best you can do is to say that, for hyperbolas x^2 - t^2 = x_0^2, as x_0 gets closer and closer to zero, the acceleration felt by observers moving along the hyperbola gets larger and larger, without bound. (Also, of course, since there's no observer that stays at the horizon, there's no clock that "is not ticking" there.)
  • #98
I'm curious: why are you so insistent on finding an interpretation of what's going on in terms of "gravitational potential"? As far as relativity is concerned, "gravitational potential" is not a fundamental concept; it's an approximation that works well in a certain domain (basically, under conditions such that gravity can be usefully treated as a Newtonian force, determined by the gradient of a potential) but does not extend well beyond that domain.
  • #99
from the point of view of someone on the rocket[/color] that is exactly what will happen and the clocks there are indeed not ticking at all but gravity at that point will not be infinite.
it is a common fallacy to assume that infinite time dilation equals infinite gravity. (time dilation is proportional to gravitational potential not gravitational field strength)
beyond that point Δt continues to increase and the clocks will be ticking backwards. (again from the point of view of someone on the rocket)
this can easily be seen with a long line of sychronized clocks using nothing more than special relativity.
an accelerating rocket can be thought of as creating a uniform gravitational field and the Δt can be shown to be proportional to the distance from the rocket so the time dilation is proportional to the potential.
  • #100
I realize this is probably not the way its usually described, but I'm basing this on a simulation that I made myself a few years ago--(well before I had any idea that there should be a Rindler Horizon.)
I decided to make a video of this, this morning and upload it to youtube.
I described the Rindler horizon as the spot that everything falls toward, but never reaches. You describe the Rindler horizon as the spot from which a light beam cannot reach us. In either case, the "spot" we are referring to is actually an "event."
They are both legitimate ways of explaining what is going on. The light coming from the Rindler Horizon can't ascend from the horizon, and the light and objects falling toward the rindler horizon approach it asymptotically, but never reach it. Objects beyond the rindler horizon, mathematically also move toward the rindler horizon, but their clocks are mathematically going backwards.
In the view of the rocket, the event at (x=0,t=0) is an event that cannot be crossed because nothing can happen there.
