Automotive Heat Transfer Calc for Oil Tank in Formula Student Car
The discussion focuses on calculating heat transfer for an oil tank in a Formula Student car, specifically analyzing an existing oil tank from an Aprilia SXV 550 engine. Key calculations involve determining the inlet and exit temperatures of the lubricating oil and assessing heat loss through conduction, convection, and radiation. Participants suggest measuring the oil's temperature and flow rate to calculate convective heat loss, while noting that radiation heat loss may be negligible. Recommendations include using appropriate heat transfer formulas like Fourier's Law and Newton's Law of Cooling. The conversation also raises the question of whether an oil cooler might be a more effective solution for managing heat flow.
beckspp
Hi Guys,
This is for my university project.I need to design a oil tank for the formula student car.The first stage is the analysis of the existing stock oil tank (Aprilia SXV 550 is the engine).I need to find out the heat lost/transferred from the of the existing oil tank.How can I calculate the inlet and exit temperature of the Lubricating oil(passing through the tank).
I need to do the corresponding heat loss calculations happening through the oil tank.
I will be considering all the modes of heat transfer
Conduction,Convection and Radiation.
Please tell me How can I justify that a particular value of heat is lost from the oil tank with the help of calculations.And what formulas of heat transfer should i use (Fourier's,Newton's Law of cooling ...?)
What is the suitable FEA package that can be used for justifying my results...?
You're going to need to know what the temperature and flow rate of the oil is coming into the oil pan, or maybe an average tempertuare of oil in the pan. Then, given a flow of air over the pan you can calculate the convective coeffcient and the heat loss through convection.
My guess is you'll be able to ignore radiation heat loss in this case.
hello
you said student Formula car...if this is right...you have big task ahead of you..can you post photos of engine and the FC
Thank you Mech_Engineer...
How should I measure these values..Any Ideas or suggestions...?
It will be helpful for me.
Well, you could start with the obvious- an http://www.summitracing.com/parts/ATM-3348-M/ ...
Why do you care about the heat flow out of an oil pan though, why not use an oil cooler?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
