How do resistor values affect the operation of a BJT transistor?
  • Thread starter Thread starter ajack
    Amplifier Bjt
The operation of a BJT transistor in saturation or amplification mode is significantly influenced by the choice of resistor values. Selecting appropriate resistors allows for the establishment of desired Q points, which determine the transistor's operating mode. The process of setting these Q points is known as DC biasing, and various techniques exist, each with unique benefits and drawbacks. Understanding these concepts is crucial for effective transistor design and application. Proper resistor selection is essential for achieving the intended functionality of the transistor.
ajack
I'm really confused between saturation and amplifier. When will the transistor work in saturation mode and in amplifying mode? Resistors are the matters. We chose the resistors so that the transistor will work in saturation or amplifying. How can we chose?
Well you choose the resistor values depending on how you want the transistor to operate. As an example you may want to choose the q points so that the transistor is mid-point biased. These Q point values are determined by the (biasing) resistors used. The process of setting the proper operating(Q) point for a transistor/amplifier is called DC biasing. There are several biasing techniques, each with its own advantages and disadvantages. Here are a few links
http://www2.engr.tu.ac.th/~lvenus/classes/le210/biasing.pdf
http://www.allaboutcircuits.com/vol_3/chpt_4/8.html
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
