Understanding the Relationship Between Velocity and Drag Force in Air
  • Thread starter Thread starter ExitSeven
    Drag
Air drag is influenced by velocity, and it is generally accepted that drag force is proportional to the square of the speed. The governing equation for drag incorporates factors such as velocity, surface area, and pressure, which plays a crucial role in both lift and drag for aircraft. Understanding the relationship between velocity and pressure is key to grasping how drag force operates. The discussion emphasizes the importance of these variables in calculating drag. Overall, a deeper comprehension of these principles is essential for analyzing air drag effectively.
ExitSeven
Is air drag proportional to the speed or the speed squared? What data did you gather to support your answer?
Can someone please provide me an explanation? Thx.
type "air drag" into google
or to narrow your focus try
"air drag +wikipedia"
without the quotes
There's a basic governing equation for drag involving velocity, surface area and a couple of other variables. I've posted it here before, but since we're not supposed to just give out answers I'm not sure if I'm allowed to or not. To give you a hint - pressure is what gives an aircraft its lift as well as what causes its drag. Drag, being a force, is pressure multiplied by the area it acts upon. So if you know how velocity relates to pressure, you can get an understanding of how it relates to the drag force.
