Effects of pressure on an air bubble
An air bubble from a scuba diver at 18.0 meters depth with a diameter of 1.0 cm will change in size as it ascends to the surface due to pressure changes. The pressure inside the bubble is affected by the external water pressure, which is higher at greater depths. As the bubble rises, the external pressure decreases, leading to an increase in the bubble's volume and diameter. The relationship between pressure and volume can be described by Boyle's Law, which states that at constant temperature, the product of pressure and volume remains constant. Therefore, the bubble's diameter will increase as it reaches the surface.
studentmom
an air bubble originating from a scuba diver at a depth of 18.0m has a diameter of 1.0cm. What will be the bubble's diameter when it reaches the surface?
assume constant temperature
I'm not sure what equation to use for this...
I know that an increase in pressure should have an effect on the size of the air bubble. But I don't know where to start.
What is the pressure inside the bubbles? What is pressure outside the bubbles? Are they the same? Different? How does the pressure inside the bubbles relate to bubble size? Given a set number of molecules in the bubble, will a higher pressure bubble have a smaller volume or a larger volume?
Answer those questions and you will have your answer.
