Triple Integrals Over General Regions
To evaluate the triple integral of xy over the tetrahedron defined by vertices (0,0,0), (1,0,0), (0,2,0), and (0,0,3), one must first determine the equation of the plane that bounds the region below. The correct plane equation is 2z + 6x + 3y = 6. This can be derived by finding vectors between points A(1,0,0), B(0,2,0), and C(0,0,3), and calculating the cross product to obtain a normal vector. The plane equation can then be constructed using the normal vector and a point on the plane. Understanding these steps is crucial for solving the integral correctly.
wubie
Hello,
First I will post my question:
Evaluate the triple integral:
Triple integral sub E of xy dV, where E is the solid tetrahedron with vertices (0,0,0) , (1,0,0) , (0,2,0) , (0,0,3)
It has been quite a while since my last calculus course so I don't remember everything. Now here is MY question: How do I find the equation of the plane in which the region E lies below?
I know from the solution manual that the E is the region that lies below the plane
2z + 6x + 3y = 6
How do I find that out?
I found three separate equations for each plane - xy, yz, xz.
6 = 2z + 6x, 6 = 2z + 3x, 6 = 3y + 6x.
And I can see the relationship between all four planes. How do I come up with the final equation of the plane
2z + 6x + 3y = 6
I should know this. I just can't remember.
Any help is appreciated. Thankyou.
Define two vectors between points A(1,0,0), B(0,2,0), and C(0,0,3). It doesn't matter which pair of points you use to make the vectors, as long as the vectors are different.
The cross product of these two vectors will be normal to the plane. Then the equation,
n_x(x-x_0) + n_y(y-y_0) + n_z(z-z_0)=0
will describe the plane.
\boldsymbol{AB}=<1,-2,0>
\boldsymbol{AC}=<1,0,-3>
\boldsymbol{AB}\times\boldsymbol{AC}=<6,3,2>=\boldsymbol{n}
6(x-1)+3y+2z=0
6x+3y+2z=6
cookiemonster
Thanks for the help cookie monster.
