Momentum and kinetic energy- pendulum component
The discussion revolves around calculating the horizontal displacement of a pendulum after being struck by a bullet. The initial momentum of the bullet is calculated, leading to the pendulum's velocity post-collision. The kinetic energy of the pendulum can be determined, which is then converted to gravitational potential energy at the maximum height of the swing. To find the horizontal component of the displacement, the conservation of energy principle is suggested, along with the use of trigonometry based on the pendulum's final position. A diagram of the system is recommended to aid in visualizing the problem.
JerG90
An 18-g rifle bullet traveling 230 m/s buries itself in a 3.6kg pendulum hanging on a 2.8-m-long string, which makes the pendulum swing upward in an arc. Determine the horizontal component of the pendulum's displacement.
MaVa1 + MbVb1= MtVt2
k.e.= 1/2mv^2
p.e.= mgh
I can find the velocity of the pendulum, but not the displacement:
230 m/s * .018= 4.4 kg m/s
4.4 kg m/s / 3.6018 kg = 1.15 m/s (speed of the pendulum with bullet after collision)
I just don't know how to find the component of the horizontal displacement. Any help would be greatly appreciated.
Once you've got the speed of the pendulum you will know how much kinetic energy it has. Also you can assume the pendulm at its maximum arc displacement has traded all that kinetic energy for gravitational potential energy.
k.e.= 1/2mv^2
p.e.= mgh
230 m/s * .018= 4.14 kg m/s
<did you miss 1 in 4.14?>
use conservation of energy principle to find height, and then try drawing a diagram of the system @ its final position. Then you just need trigonometry to get the x component.
