Calculating Time for Block to Reach Max. Amp. After Spring Collision
  • Thread starter Thread starter Momentum09
    Amplitude Spring
A block of mass 0.28kg attached to a spring with a spring constant of 12N/m undergoes simple harmonic motion with an initial amplitude of 0.2m. After being struck by a bullet with a mass of 4.4g traveling at 53m/s, the block's velocity is calculated to be 1.309 m/s. The maximum amplitude after the collision is determined to be 0.3246m. The equation x = Bsin(wt + alpha) is suggested for calculating the time to reach maximum amplitude, but specific values for the variables need clarification. The participant successfully finds the answer after seeking assistance.
Momentum09
A block of mass 0.28kg is attached to a spring of spring constant 12N/m on a frictionless track. The block moves in simple harmonic motion with amplitude 0.2m. While passing through the equilibrium point from left to right, the block is struck by a bullet, which stops inside the block. The velocity of the bullet immediately before it strikes the block is 53m/s and the mass of the bullet is 4.4g.
How long will it take for the block to reach maximum amplitude [which I calculated to be 0.3246) after the collision?
M1V1 + M2V2 = (M1+M2)Vf
x = Bsin(wt+alpha)
I found Vf = 1.309 m/s
I think the answer will have to solved using the equation, x = Bsin (wt + alpha), but I don't know what numbers to plug in for those. Any help would be greatly appreciated!
I got the answer. :)
