Quick Question - Moments about a force
  • Thread starter Thread starter jmcmillian
    Force Moments
To find the resultant force about point P from two given forces F1 and F2, establish position vectors from P to each force's point of application and simply add the vector components without multiplying by magnitudes. The resultant force is a vector sum of the forces in their i, j, k components. For calculating the moments of the resultant force about point P, identify a point on the line of action of the resultant and use the formula (r - OP) X R, where r is the position vector of that point, OP is the position vector of point P, and R is the resultant force. Clarification on the distance between F1 and F2 from P is unnecessary for this calculation.
jmcmillian
Hi there, quick conceptual question just to make sure I know what I am doing...
I am given two forces, F1 and F2, in vector form with given magnitudes.
(I) Find the resultant force about point P (given).
(II) I am also asked to find the Moments of the resultant force about point P.
(I) I establish position vectors from P to each point (I'll call it A for F1 and B for F2) and multiply by magnitudes. Then add to get the resultant force about P.
(II) Then for the second part, I cross my resultant force about P with the "r" for the resultant force, which would be the distance between F1 and F2 from P?
It's that last sentence where you can see I'm unclear at. Any help would be greatly appreciated!
If the forces are given in vector forms, i.e., the i, j, k components are given, just add them to get the resultant. Resultant force about a point does not mean anything. For finding the resultant, you need not multiply anything.
For the 2nd part, you have to find a point on the line of action of the resultant. If posn vector of that pt is r wrt to origin O, then the moment about P is (rOP) X R, where OP is the posn vector of pt P, and R is the resultant.
