Extracting Divisors: A Simple Guide for Adding Factors
  • Thread starter Thread starter soul5
To extract divisors of a number in C++, initialize a sum variable to zero and iterate from 1 to n, checking if each number is a divisor using the modulus operator. If a number is a divisor, add it to the sum. To store all divisors, use a vector and push back each divisor when the condition is met. It's more efficient to limit the loop to n/2, as no divisors greater than n/2 exist, but ensure to include n itself as a divisor. The corrected loop should run from 1 to n, and remember to check for syntax errors like missing semicolons.
soul5
Ok this is what I did
int n;
cout << enter number;
cin >> n;
for (int i = 1 ; i < n ; i++ )
if ( n % i == 0 )
I could use some help please like how to I extract the divisor?
so I can add them. Thanks a lot.
Technology news on Phys.org
Your if condition tells you if i is a divisor. Since you said you want to add up all the divisors you have to declare an identifier, say int sum=0; at the start.
So you can do this should the if statement be satisfied:
if(n%i==0)
sum += i;
If you're writing a function, then you'll want to return sum after you're done. Alternatively if you want all the divisors individually, one way is to initialise an integer vector, say vector<int> divisors (remember to #include <vector>), and use divisors.push_back(i); each time your if condition is true.
More importantly you can improve your program slightly by specifying your for loop as :
for(int i=1;i<=n/2;i++) since it is evident that there cannot be any divisors of n which is larger than n/2.
soul5 said:
int sum=0;
int n;
cin >> n;
for (int i = 1 ; i <= n ; i++ ) {
if ( n % i == 0 )
sum += i;
cout << " sum is " << sum << endl;
changed again
Well it looks ok to me. You forgot a semiconlon for your sum statement though. The best way to know if it'll work is to actually try it out. One thing overlooked earlier: your for loop doesn't allow i to be "n", which it should, since for any number n, n itself is a divisor of n. So change it to i<=n.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
