Relativistic Expression for Energy of Quantum State of Harmonic Oscillator?
The discussion revolves around deriving a relativistic expression for the energy of a quantum harmonic oscillator, specifically for high school seniors familiar with special relativity and non-relativistic quantum mechanics. The participant presents the standard energy formula for a quantum state and attempts to relate it to relativistic kinetic energy, suggesting that under certain conditions, the angular frequency can be expressed in terms of linear velocity. There is uncertainty about the interpretation of "comparable to" in the context of kinetic energy, indicating that it could vary significantly rather than being strictly equal to mc^2. The participant seeks clarification on their approach and how to express the radius in terms of the quantum number n. The thread remains unresolved, highlighting the complexity of integrating relativistic concepts with quantum mechanics.
ephedyn
This is supposed to be a question for high school seniors who've had instruction in introductory concepts of special relativity and non-relativistic QM. According to my TA, he isn't too certain if it can be done within these confines but nonetheless I've attempted the problem... Please let me know if I'm doing it wrong (quite sure I am); or if I'm on the right track, how to reduce r in terms of n. Thanks in advance!
A particle of mass m vibrates as a harmonic oscillator with angular frequency \omega. For this harmonic oscillator, the general expression for the energy E_n of the state of quantum number n is
E_n = (n - \frac{1}{2})\hbar\omega
Suppose that the angular frequency \omega is so large that the kinetic energy of the particle is comparable to mc^2. Obtain the relativistic expression for the energy E_n of the state of quantum number n.
Relevant equations and the attempt at a solution
Considering the relativistic kinetic energy E_k of the particle,
E_k = (mc^2)(\gamma - 1)
If E_k \approx mc^2
then \gamma - 1 \approx 1
\therefore \gamma \approx 2
Expressing angular frequency in terms of linear velocity in \gamma
\gamma \equiv \frac{1}{\sqrt{1 - v^2/c^2}}
\omega = \frac{c}{\sqrt{2}r}
where r is the radius of the oscillation
\therefore E_n = \frac{(n - \frac{1}{2}) \hbar c }{\sqrt{2}r}
Posting again to put this thread above again, since it remains unsolved.
Thanks for looking. :frown:
Well, I don't know the solution, but I'll just remark that "comparable to" isn't synonymous with "approximately equal to". So the KE could easily be 1/2 of, or twice, the rest energy for example.
