What is the maximum tension in cable ABAD?
  • Thread starter Thread starter Apprentice123
    Axis Moment
The discussion revolves around calculating the maximum tension in cable ABAD while ensuring that the moment at point A does not exceed 217 N.m. The problem involves a small boat suspended from two brackets, with specific forces acting on it. The calculated maximum tension in the cable is determined to be 196 N. Clarifications are provided regarding the relationship between the moment and the tension in the cable. Understanding this relationship is crucial for solving the problem effectively.
Apprentice123
A small boat hangs from two brackets, one of which is shown in the figure. It is known that the moment, on the z axis, the resulting force Ra applied in the point A of support must not exceed the value of 217 N.m, in value absolute. Determine the more value possible the traction force in cable ABAD.
Not understand the problem. What is the issue? How can I fix?
Figure:
http://img21.imageshack.us/my.php?image=318x.jpg
Answer:
196 N
Hi Apprentice123! :smile:
It means, if the moment of RA about that z-axis is 217 N.m, what is the tension in the cable? :wink:
