Solving a Circuit: Find Ceq, Q, & U
  • Thread starter Thread starter cristina045
    Circuit
The discussion focuses on solving a circuit problem involving three capacitors (C1, C2, and C3) with a voltage of 200V. The user attempts to find the equivalent capacitance, charge on each capacitor, and total stored energy but expresses confusion about the circuit configuration, particularly whether C1 and C2 are in series or parallel with C3. Responses clarify that the user's approach to calculating the equivalent capacitance is mostly correct, but the voltage across C1 and C2 is not simply 200V, as they share the total voltage. The calculations for charge and energy are also discussed, emphasizing the need for a clearer understanding of voltage distribution in series and parallel circuits. Overall, the user seeks more straightforward explanations to grasp the concepts better.
cristina045
For the cicuit shown, the voltage is 200V, C1= 4microF, C2= 15microF and C3= 12microF
(i drew it on paint)
Find
a) the equivalent capacitance between the terminals
b) the charge stored on each capacitor
c) the total stored energy
Ceq= 1/c1 + 1/c2 +1/c3
or
Ceq = C1+C2+C3
C=Q/V
I think this is the right equation for the energy stored in a capacitor:
U= QV/2=CV^2/2
Ok I'm really not sure because I'm having a lot of trouble with figuring circuits out. I think C1 and C2 are in series but in parallel with C3. For a) what i did is :
Ctot = 1/Ceq + C3
and
1/Ceq = 1/C1 + 1/C2
Therefore Ct = 3.15microF + 12microF
Ct= 15.15microF
b) I would use C= Q/V
so Q1 = 8*10^-4 C
Q2= 3*10^-3 C
Q3= 2.4*10^-3 C
c) U=CV^2/2
my equivalent capacitance was 15.15microF and my voltage was 200v, therefore my U should be 0.303J
It seems to me that b and c were too easy to get. Besides, I'm not even sure my a) part is right. I'm so confused...
the picture i drew is at the bottom, it's just pending approval.
In series combination of capacitors, charges in each capacitors must be the same.
Hi cristina045! :smile:
(have a mu: µ and try using the X2 and X2 tags just above the Reply box :wink:)
i'm not even sure my a) part is right.
Your a) is fine,
(except of course it should be Ceq + C3 in the first line :wink:)
(and personally I'd have used something like C12 instead of Ceq)
so Q1 = 8*10^-4 C
Q2= 3*10^-3 C
Q3= 2.4*10^-3 C
Your Q3 is fine, because the voltage across C3 is 200 V.
But the voltage across C1 (or C2) is not 200 V.
The total voltage across both of them is 200 V, so use that (and the fact that, as rl.bhat :smile: says, their charges must be the same).
thank you guys soooo much
i'm really having trouble understand these things
it's so much easier to understand and solve with clear explanations :)
