How Does HCl Concentration Affect the Rate of Mg Reaction?
  • Thread starter Thread starter gsingh2011
    Hcl Rate Reaction
In the lab investigating the reaction rate between magnesium (Mg) and hydrochloric acid (HCl), the focus is on how changing the concentration of HCl affects the reaction time. It is observed that higher concentrations of HCl lead to quicker reactions, as indicated by shorter times for Mg to disappear. The discussion highlights the challenge of discussing the concentration of solid Mg, as it does not change during the reaction. Instead, the rate of reaction can be described by the inverse relationship between time and concentration of HCl. The solution to the confusion about measuring reaction rates without a concentration of Mg is found through stoichiometry, allowing for the calculation of moles of product and subsequent molarity. Consistency in using Mg ribbons of the same mass and surface area across different trials is recommended to ensure reliable results.
gsingh2011
I have to do a lab investigating factors that affect the rate of reaction between Mg(s) and HCl(aq). I decided to change the concentration of HCl. I timed how long it took for the Mg to completely disappear when the HCl was in excess and the amount of Mg used is constant. Obviously the higher the concentration, the lower the time, the faster the rate of reaction. My question is that since I'm using solid Mg, I can't really talk about the concentration of that... so is it simply enough to say that the lower times means that the rate is faster? I can't say rate=Delta[Mg]/Delta(t) if there's no concentration of Mg. I'm just confused on how to correctly explain this without a concentration, what do I do?
Chemistry news on Phys.org
Nevermind, I figured out the moles of a product using stoich. and then I could find the molarity of that :)
Nevertheless, things do get tricky when it comes to defining concentrations (or activities) of solids. For the scope of this lab, I think you would be well-advised to be consistent with your use of Mg ribbons between different runs - make sure they have the same mass and roughly the same surface area.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
