Faraday Rotation experiment question
bcjochim07
I used a Faraday Rotator to measure the Verdet constant of SF-59 glass at 650 nm wavelength. In this setup, the glass sample was placed inside a solenoid, and a diode laser was aligned to enter the solenoid and go through the sample. The angle of rotation of an analyzer polarizer (placed where the light exited the solenoid) necessary to return to a fixed value of intensity was measured as a function of current through the solenoid. The intensity value was measured by reading the dc output of a photodiode detector. My question: Does the magnetic field affect the photodiode detector in any way?
Verify experimentally. Try varying the distance of the photodetector from the end of the solenoid and note the current readings as a function of distance. Do you expect laser intensity to vary with distance? If not sure, measure it without a magnetic field applied and use these readings to adjust for any possible magnetic effects when a field is present.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
