Calculating Q (first moment of inertia) above and below the neutral axis
The discussion focuses on calculating the first moment of inertia (Q) above and below the neutral axis for a specific cross-sectional shape made of two plates. The user initially finds a discrepancy between the calculated Q values, with Q above being 21.31 and Q below 30.03. After receiving feedback, the user realizes the mistake was in using the wrong distance from the centroid to the neutral axis for the Q above calculation. The correct distance should be 3.875 inches instead of 2.75 inches, leading to accurate Q values. The user expresses gratitude for the guidance received in resolving the issue.
tn3003
This is the cross sectional are of the shape: http://img38.imageshack.us/i/shapep.jpg/"
It's made of 2 10"x1" plates. (Picture is not to scale)
Q (first moment of inertia) above and below the neutral axis should be the same. For some reasons, my calculated Q above is not equal to Q below the NA.
Taking the datum at the bottom
y bar = (10*0.5 + 10*6) / (20) = 3.25"
Q above = 7.75 * 2.75 = 21.31
Q below = 2.25 * (2.25/2) + 10 * 2.75 = 30.03
21.31 =/= 30.03
Someone please point out my mistake.
Your Q below is corect, but in calculating thte Q above, the distance from the centroid to the N.A. is not 2.75. I think you may have just written down the wrong number.
OK I see it now. The distance for Q above should be 7.75"/2 = 3.875"
I was using the centroid of the whole shape, which gave me 7.75" - 5" = 2.75" and that's wrong.
Thank you PhanthomJay for not giving out the answer and let me figure it out myself. I really appreciate it.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
