Multivariable max rate of change
allenh98
The equation z(e^(xy)) + z^5 + y = 4 implicitly defines z as a function z = f(x,y) near (0,2,1)
(a) find df/dx and df/duy where x = 0, y = 0, and z = 1
(b) find the maximum rate of change of f at the point (0,2)
sorry, my first post here not sure what i need to write in this section
sol'n (a):
df/dx = yz(e^(xy))
df/dy = xz(e^(xy)) + 1
then i sub in the co-ords given to find
df/dx = 2
df/dy = 1
part (b) is where I am confused, since they only give us f at point (0,2), is it implied that we plug in f(0,2) and get z = 1 and solve the gradient?
here is what i did:
grad(f) = [yze^(xy)]i + [xe^(xy) + 1]j + [e^(xy) + 5z^4]k
substitute (0,2,1)
2i + j + 6k
= sqrt(41)
You mean (0,2,1). (0,0,1) isn't on the surface.
sol'n (a):
df/dx = yz(e^(xy))
These partials aren't calculated correctly. Remember that z is implicitly a function of x and y. So if you differentiate
ze^{xy} + z^5 + y = 4
with respect to x, you must use the product rule on the first term and you must differentiate the z5 implicitly with respect to x. Then solve for zx. Similarly for zy.
here is what i did:
substitute (0,2,1)
2i + j + 6k
= sqrt(41)
Almost OK on part b. But 2i + j + 6k is not equal to sqrt(41). One is a vector and the other is a scalar. What did you mean to write there?
Thank you for your help! I have my midterm in 3 hours lol. I meant to write the maximum value of the gradient, not direction. We haven't learned implicit partial differentiation, so I assume it will not be asked on my test. But just in case it is, how do I implicitly differentiate z wrt x?
And yes, you are correct it isn't (0,0,1) it was a typo sorry.
To differentiate
<br /> ze^{xy} + z^5 + y = 4<br />
with respect to x you would differentiate every term with respect to x, noting that y doesn't depend on x and z does, and write:
z_xe^{xy} + zye^{xy} + 5z^4z_x + 0 = 0
and solve for zx.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
